Question about Acer Computers & Internet
I want to disable the onboard graphics card in an Acer e500 desktop. Just installed a GeForce 8500 GT card and the machine now crashes intermittently so I am assuming the onboard card is causing a conflict
  • simhughes11 Jun 23, 2008
    thx
    just tried it, am testing to see if i crash again.
    will write again shortly.
To disable the onboard graphic card you need reboot your root pc and go into setup look for option for to turn it off
Posted on Jun 23, 2008
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
Free download Installation geforce 8500 512 bm
Download the driver here at nvidia:
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
Select:
1.Geforce
2.Geforce 8 series
3.Geforce 8500 GT
4. Your operating system 32 or 64 bit
5.Language
6.Press seach and download and install.
Hope this will help you.
Mar 22, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
I have a motherboard with an Integrated ATI HD 4200. When I install my EVGA GeForce 8600GT the fan runs but the card itself is not detected in device manager or anything like that. I disabled the onboard...
You don't disable it from there. Reenable it again and do it right: you uninstall its drivers from Programs and you reboot twice; you install the new card and you connect the monitor to it; when the pc starts you go directly in the BIOS and you disable the onboard card from there; you reboot one more time and you install the drivers for the new card.
Feb 26, 2011 | Evga e-GeForce 8600GT, GeForceĀ® 8600 GT, ...
I want to switch out AM 5641-u5630A graphics card for a GeForce GT 220 so that I can run two monitors. Where is the AM 5641-u5630A graphic card located? Do I plug the GT 220 into the brown female...
In this desktop the video card has been part of the motherboard so you don't remove it - you insert the new card in the brown PCI-E 16x connector, connect the monitor to it then you go in the BIOS and disable the onboard one.
Jan 02, 2011 | Acer Aspire m5640 PC Desktop
Geforce 8500 won't show on computer and fan is working but no show how to fix
you may have to dis able the Onboard  graphics system and may need to check some things
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
Oct 02, 2009 | PNY Verto GeForce 8500 GT 512MB DDR2 PCI...
Upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
Apr 29, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Installing New Graphics Card.How do you disable the onboard GC?
To disable the onboard graphics go into your CMOS settings and in there you should find something that says Graphics choices should be onboard or add on or some other form. It all depends on who made your BIOS. As far as a sound card not sure.
Feb 27, 2009 | Dell Optiplex GX260 Desktop PC - Intel P4...
Disabling onboard video on Acer aspire m1640
you cannot dissable the on-board graphics in the bios, in the graphic options you must choose which port you want to use, if you have a pci express card then chose pci as the primary graphics, press ok then F10 your pc will reboot and the on-board vga won't load up in windows
good luck
Nov 14, 2008 | Acer Aspire M1640 Refurbished Intel...
I have an acer aspire m1610, I'm desperately trying to disable the onboard video card in order to add a geforce 8500 but there's no way to disable the onboard video card via the bios and the computer wont...
Are You sure the graphics card is not defect?
When I installed a graphics card instead of the onboard
circuit, the SIS Mirage was disabeled automatically.
I have installation CD for the graphics, of course.
Also, I thought that disabeling devices could be done
through the control panel, "hardware devices".
Sep 13, 2008 | Acer Computers & Internet
Computer is not starting
make sure that the RAM is seated right, and also the new Graphic card, did you take ESD safty precautions?.
May 05, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
Computers & Internet Logo
226 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
