Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698244
Generic problem for all Vacuums
I require a new drive
Posted by martiy on Jun 23, 2008
I require a new drive belt for my upright vacuum cleaner
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. In order to change your belt I would need to know the brand name and the model # in order to give you the correct information to change your belt, so a little bit more information needed as to what you have and then I can direct you in the belt change. Normally there are screws in the bottom of the vacuum and once you remove the screws or clips you can either change it from the bottom or the top cover will lift off and then you can get @ the belt from the top. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: I need to know how to repalce the drive belt in a Sebo upright cl
Thanks to its automatic height-adjust feature, the Sebo X4 has two drive belts, one from the motor to the height-adjust sensor, and another from that sensor to the brush roller. To access them,first remove the base from the handle, undo the four recessed screws on the underside of the base, then turn it over and lift off the cover. You will then see the belts. The rest should be obvious (it's a while since I've done one of these, but I think you may have to loosen the screws holding the height-adjust sensor before you can slip the belt off).
I hope this helps. Any further problem, just re-post here and I'll do my best. Good luck!
SOURCE: where is the belt on a dyson upright vacuum?
There is no drive belt on this model - its a cylinder pull along model.
If there's a problem with the turbo brush you can flip open the base of it by removing the screws, check that the toothed belt is in place and there is no clogs of dirt between the turbine and the brush bar.
