Question about Admiral AW22 Top Load Washer
Drum has come loose
I think the drum has come loose, I can actually move it from side to side, it makes a loud noise when spinning, is there an easy way to repair it please
  • 1 more comment
  • ceramicjonc Jun 29, 2008
    i have exacally the same problem, could you let me know if you find the answer.i shall do the same. thanks jon
  • Swtmarie2346 Jul 10, 2008
    I think I have the same issue..during the spin cycle it makes a super loud noise but then calms down after a while and then will do it again on the next spin cycle for about a minute or so. Could this be the drum possibly coming loose?
  • icemanjtice Oct 02, 2008
    tube bangs ,way to noisey,
Thanks , i'll try it.
Posted on Oct 02, 2008
    Scholar:
  • 116 Answers
The drum must reach full speed when spinning, otherwise it bangs about everywhere, centrifugal force keeps it up-right like a gyro, the machine is not getting upto speed, try replacing the drive belt.
tilt the machine backwards for access to the belt below the machine, simply pull off and replace wih new by easing the new belt onto the pulleys.
Posted on Sep 11, 2008
Auto washing machine drum vibrates makes loud noise
When machine is empty use fingers to try and move drum side to side. Is there excessive movement? 2 to 3 mm is ok. If drum moves to much it will be the drum bearings. Easy fix for an engineer or competent diyer. Millions of how to videos on utube.
Oct 04, 2015 | Whirlpool Washing Machines
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Noise from drum
This is difficult to work out as there are so many different symptoms. Here are my thoughts -
Dust from carbon rushes is black. Grey dust usually comes from a loose concrete weight. Loose tub weights are rare on this model but they cause a loud knocking noise which is often worse when the washing machine is revving up to spin and dying down from a spin (suspension problems are also often worse at this safe too). It's not normally a metallic sound though.
If the noise is coming from the motor banging against the sides of the machine then it will make the machine move when it happens. The whole machine may jump or move to one side. The motor often thumps the side of the washing machine on Hotpoint washers where the motor is fitted at the top of the tub and over to the right hand side. This is a daft place to fit a motor and only .I think they've eventually stopped now though.
It is normal to be able to push the drum to the side so that the motor hits the casing. If the suspension has gone, the tub should be twisted and leaning to one side more than the other or it just could be very loose. It's difficult to check suspension if you don't know how it should feel.
If the noise is coming from the inner drum hitting the heating element or throwing an object like a £1 coin (trapped between the inner drum and the outer tub) around, then the washing machine will be stable but the noise would still be a horrible metallic knocking. This is one cause I suspect.
Thank you for contacting Fixya.com
Aug 30, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
When washer agiates it makes a loud squeaking noise, what can it be?
Aug 30, 2009 | Washing Machines
My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Drum makes loud whinning noise when spinning at high rpms.
Remove drive belt.and turn drum by hand, if it feels rough or sounds noisy, then the main drum bearings have failed., also check that the main drum pulley is not loose. If you think it is the bearings, then it is quite an expensive repair.
Plz rate this solution.Thanks.
Dec 25, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
Admiral AW22 Top Load Washer Logo
217 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
