Question about Sony Audio Players & Recorders
TC-WR99ES Deck powers up with indicator lamps but when I press play, reverse, or ff or rr on either deck A or B, the lamps initiate but no mechanics...also neither cassette door will open with controls. I think I have problem with the mechanism controller IC802 or IC809 which is between the switch and the controller. It is a US model but I have been using it in Japan where the voltage is somewhat less and 50 HZ. Over time I lost control, first over one deck then the other...now I do not have any control. Of the top of your head, do I sound headed in the right direction.
  • mrtruax May 11, 2010
    Need to get a couple of things...like a Fluke meter before I verify...so it will be this weekend before I'm ready to tell more. Thanks for the response...I'll be back by this time next week.
    Sergeant:
    Champion:
  • 319 Answers
Not knowing what brand/model tape deck you have, I would suggest you make sure the belts are good before you get into replacing servo ICs
Posted on Aug 03, 2008
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
Machine will play cassettes but not rewind or ff
Most likely the unit needs new belts. Also possible that a switch has broken. the switched is underthe tape deck on the circuit board.
May 06, 2011 | Panasonic RR-830 Desktop Cassette...
Both decks eat tapes when fast forwarding, normal play is OK
it never eate tape in ff or rew mode . look for back tenssion
Jun 21, 2010 | Sony TC-WA7ESA Single Cassette Deck
Tape Transport issue
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Mar 19, 2010 | Audio Players & Recorders
Sony tc-wr535 won't eject. Tape stuck. Won't play cassette on either deck A or B .makes noises but won't FF or play, gets stuck and wont eject. Will belt conditioner work? What do I use?
The problem, according to messages on your site, is that the belts are old and have stretched. There is a great step by step tutorial on www.Instructables.com with pictures and all. Parts are not too hard to find on search engine. Looks like less than $25 to fix.
http://www.instructables.com/id/How_to_replace_the_belts_on_a_Sony_TC_WR535_Dual_C/
Jan 16, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
The power is on but the motor will not turn the tape drive. Does anyone know a good repair shop?
Hmm, when you press play, can you feel the motor turning, do the spindles turn on fast forward or rewind? If so you may have one of two problems. First check to see if the cue button is is depressed. If it is jammed, the deck will FF and RR but won't play. If it's not that, but the motor still spins, the motor is no longer making contact with the flywheel. If you have a repair manual, dismantle the deck and check out the motor contact
May 10, 2009 | Sony Walkman WM-D6C Personal Cassette...
Problem with deck B on Pioneer CT-W205R
Better tape decks, like Pioneer, may use a different mechanism for record/play than FF & REW. So it sounds like a belt or mechanical link for the REC/PLAY has failed.
Dec 20, 2007 | Pioneer CT-W205R Single Dual Cassette Deck
148 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
