Question about JVC GR-D20EK Camcorder
Jvc gr-d370as - help connecting to Mac - Date and Time Setting
Hi
I am trying to connect the above camcorder to my mac - using firewire cable. For some reason when I try to import into IMovies, the camera is not being recognised.
I troubleshooted on my mac (G4 ibook) - and it says I need to change the date and time settings on the JVC - which I had never set.
I have lost my manual and cant for the hell of me work out how to do it.
Can someone advise me how to change the date and time on this machine?
Thanks!
Hi there on the front there is a small wheel turn your switch to the letter (m) then press down the small wheel on the right of machine, this will give you the menu so you cant change date from that hope that helps
mike
Posted on Dec 01, 2008
Step by step instructions to transfer recorded videos from jvc gr-d370u to Pc, please.
First, you need a Firewire connection (also called IEEE 1394). Most of PC computers don't have it, including mine. I bought a cheap Firewire card and installed it into an empty PCI slot, costed about $15.
I hope you don't have the USB cable and the firewire cable plugged into your computer at the same time. That can break things.
With the firewire cable plugged into the DV port of the camcorder and the firewire port of the computer and the camcorder is in Play mode (and plugged into the wall AC power with the power adapter), are you saying that when you launch MovieMaker and "Capture", the video camera is not recognized?
There are only two conditions that can cause this:
1) The firewire400 port on the computer is not working properly (how do you know it is working?). If you are using Vista Home Basic, chances are good that the IEEE1394a firewire port drivers were never loaded... so, that will be your first step. Get that port working and you'll be ready to go.
2) The DV port on the camcorder is not working properly. This could be for several reasons, but lets hope the DV port was not fried if you ever had the USB and firewire connections to your computer at the same time... Reset the camcorder to factory defaults by disconnecting all cables, removing the rechargeable battery and removing the little date/time button battery inside the camcorder. Wait for about 20 minutes. Put the button battery back in, then put the rechargeable battery back on. Set the date and time. Connect the firewire cable to the DV port, connect the AC power adapter to the wall, connect the other side of the firewire cable to the firewire port on the computer, launch MovieMaker - will it "Capture" from the video tape?
Anyone you know nearby with an Apple Macintosh and iMovieHD? You will need a 4-pin to 6-pin firewire cable and the AC power adapter. If it works with the Mac, we know it is not the camcorder's DV port. If it does not work, chances are good the camcorder's firewire port is bad.
Hope this was helpful?
Jan 30, 2011 | JVC GR D370US camcorder Mini DV
What cable do i need to connect my jvc model no. GR-D340EK dvc to my computer. i want tobe able to convert my tape to disc.
how can I connect connect my jvc digital mini dv camcorder model no. GR-D370AS to my computer. i want to be able to convert my tape to disc.
pradip
Jan 11, 2010 | JVC GR-D370 Mini DV Digital Camcorder
My Macbook Pro also did not detect the connected GR-DVP9AG
The old Camcorders (which using tapes) need to use firewire 1394 connection (4 t0 4 or 4 to 6) to transfer video to PC/ Mac.
Sep 21, 2009 | JVC Cybercam GR-DVP9 Mini DV Digital...
Unable to download video from JV dvl520 to my mac
Is it connected with a firewire cable? Have you been able to import the video before to your Mac?
If it it says it is in USB Mode - then change the camera menu setting to DV.
Power off the camera, shut down iMovie - power on the camera then launch iMovie check again. (Assuming your using iMovie).
Dec 20, 2008 | JVC Cybercam GR-DVL520 Mini DV Digital...
JVC GR-DVL20E
i HAVE THE SAME CAMERA AND HAVE ALWAYS CONNECTED USING A FIREWIRE LEAD WHICH I PURCHASED SEPERATELY it's under oneof the rubber flaps and is called DVOUT. You will need to purchase a firewire lead which has that small connection on one end and whatever size your firewireport connection is, on the other
Nov 24, 2008 | JVC GR-DVL20EG Mini DV Digital Camcorder
JVC GR-D50 not seen by PC or Mac via Firewire
Could it be a bad cable or a bent/broken pin where the cable is connected to?
Nov 11, 2008 | JVC GR-D50 Mini DV Digital Camcorder
JVC model - GR-D370AS driver
I am owning one JVC GR-D370AS.
I wanted to connect the same to Yahoo messenger to use as webcam
Aug 06, 2008 | JVC GR-D20EK Camcorder
Jvc gr-d72u
use firewire cable from your dv port to stream video-4-4 pin for laptop 4-6 pin for mac or tower
May 17, 2008 | JVC Cybercam GR-D72 Mini DV Digital...
Jvc digicam gr-d370as
I HAVE A JVC GRD370 AS ITS USB NOT CONNECT TO PC HOW IT IS CONNECTED/
Dec 23, 2007 | JVC GR-D20EK Camcorder
JVC GR-D20EK Camcorder Logo
253 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
