Samsung N13013B Netbook Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows cannot find 'x:\WinClon\Manager1.exe'. what is mean??
Anonymous
Level 2:
New Friend:
  • Expert 145 Answers
  • Posted on Nov 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
145
Questions
0
Helped
34540
Points
419
Ok so it can't find it. what problem are you having with your computer??
if no problems.... may I suggest a copy of Ccleaner by piriform ....you can down load it for free @ Cnet.com ... **** cleaner should be used weekly...
Go to downloads at that site.. please only accept Ccleaner by Piriform its free
1 Related Answer
Anonymous
  • 3940 Answers
  • Posted on Jan 25, 2011
SOURCE: windows can not find x:\winclon\Manager1.exe what
See post #3
http://newyork.ubuntuforums.org/showthread.php?t=1648714
Everytime i open my command prompt my PC reboots. how can I fix it?
This is a virus activity which prevents to use command prompt on the infected machine, this virus is called PC-OFF.bat trojan which turns off or shutdown your computer when ever you try to use command prompt by any means.
The infected computer restarts on opening command prompt.
This PC-OFF.bat virus creates the following files
    • password_viewer.exe
    • bar311.exe
    • photo.zip.exe
    • pc-off.bat
at the following locations
    • c:\windows\bar311.exe
    • c:\windows\password_viewer.exe
    • c:\windows\photo.zip.exe
    • c:\windows\pc-off.bat
Another variant of the this virus is recognized as bar311.exe virus A.K.A. winzip123 which will have almost the same symptoms and when ever you boot your Windows Xp computer in safe mode it will say a message Thank You!!! Password:Winzip123
Let's find out the fix to remove this shutdown virus completely from computer.
Fix:
1. Open Task Manager by pressing Ctrl+Shift+Esc, click the process tab and locate the process named 'password_viewer.exe' or 'bar311.exe' or 'photo.zip.exe' one by one and right click and select 'End Process'
2. Open Start Menu >> Run, type regedit and press Enter key or OK button
3. Navigate to the following path
HKEY_LOCAL_MACHINE \ SOFTWARE \ MICROSOFT \ WINDOWS NT \ CURRENTVERSION \ WINLOGON
4. Locate the key named Userinit in right pane
"Userinit" = C:\WINDOWS\system32\userinit.exe,bar311.exe"
double click and remove the text 'bar311.exe' from the above
OR
"Userinit" = C:\WINDOWS\system32\userinit.exe,photo.zip.exe"
double click and remove the text 'photo.zip.exe' from the above
OR
"Userinit" = C:\WINDOWS\system32\userinit.exe,password_viewer.exe"
double click and remove the text 'password_viewer.exe' from the above
Note: Please make sure after editing the above Userinit key value it should be only
C:\WINDOWS\system32\userinit.exe (as shown in the image below)
5. Navigate to the following path now
HKEY_CURRENT_USER \software\microsoft\windows\currentversion\explorer\advanced
Change Value of the following registry Key's :-
"Hidden"=dword:00000001 (1) - Change to '1'
"HideFileExt"=Dword:00000000 (0) - Change to '0'
"ShowSupperHidden"=Dword:00000001 (1) - Change to '1'
6. Navigate to the following registry path
HKEY_CURRENT_USER \software\microsoft\Command Processor
Find the registry key named autorun, right click and delete this key. The value of the key would be autorun=c:\windows\pc-off.bat
7. Open notepad and type the following commands
@echo off
del /a /f c:\windows\bar311.exe
del /a /f c:\windows\password_viewer.exe
del /a /f c:\windows\photo.zip.exe
del /a /f c:\windows\pc-off.bat
pause
Save it as remove-pc-off-virus.bat and double click to run it. Or just download this batch file here and run it by double click.
8. Search for bar311.exe OR password_viewer.exe OR photo.zip.exe OR pc-off.bat and delete these files where ever found on your computer.
9. That's it, Enjoy the pc off virus is now completely removed from your computer.
I need to download unlockhd.exe for 64bit windows 7
What is the .exe file for? I mean what are you trying to do
Get this message upon boot up of samsung ultrabook: z:\WinClon\Manager1.exe The system cannot find the drive specified.
Sounds like u got a virus. My suggestion is don't open up any mail or any sites that your not sure of.
4helpful
2answers
1helpful
My samsung netbook wont bootup, i have tried to use the systm restore mode and still nothing happends. it says that, the file or diretory\winclon\logs\2011-03-28 txt is corrupt and unreadable. then says to...
If you have an option to run check disk then you should let it run. If not there should be a way to access it. For additional help could you please provide the version of windows that you are running?
Uninstalled the camera but the "vm_sti.exe" is still eating my cpu
Your post ..."C:\WINDOWS\VM_STI.EXE...clean this from my pc..." would mean remove/delete.
Initially, pls try to:
  • Uninstall the Philips SPC 200NC;
  • Run in Safe mode and delete C:\WINDOWS\VM_STI.EXE;
  • goto Start, Run, type "msconfig", click on Startup, uncheck reference(s) to C:\WINDOWS\VM_STI.EXE;
  • open Windows Task Manager, Applications (or Processes), highlight VM_STI.EXE, click on End Process button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
