Question about Microsoft Windows XP Professional
Windows XP Unusually Slow Startup
I am running Windows Xp Media Center edition. When booting up, there is a long delay (30-90 seconds) at the "Welcome" screen. After that has passed, my wallpaper displays but I need to wait another 1 or 2 minutes before the taskbar or icons show. I have a fast computer and plenty of ram. I disabled some services with msconfig months ago but the slow booting happened this week. I was desperate and edited the prefetch to 3 (i don't know if that harmed or hurt it). The newest change I can think of is that i installed a new HP printer. If there are any ideas, please help. Thanks a bunch to everyone in advance. I have a Media Center PC with dual boot with 1.5GB RAM, 2.8GHz Pentium D. The Start Up is slow. I have a similar problem. I used a software(boottimer.exe) to measure my boot speed. My boot time reach 130 secs. For me that is too long.I tried reinstalling my window xp. And the time needed to boot the window xp is just 25 secs! That solves my problem for a while. But after using it for a week the time increase to 90 secs. I just install 2 software after the reinstallion. Why does the windows xp took so long to boot??? As far as is know Windows only need +-30 secs to boot.Is there any software that can help me???
  • 24 Answers
Try removing programs from the start up one at a time until you figure out what is causing the slow down
Moore than likely it is a corrupt or bad registry entry, window looks for software that is no longer there or corrupted, more information on windows xp slow startup here.
Browse through the articles, some good information
Posted on Mar 21, 2009
    Guru:
  • 859 Answers
There is a program called Boot Speed you can find by searching inside of MajorGeeks.com
Otherwise, I'd like to know what antivirus software you are using. Some antivirus programs can really slow down a bootup time because they usually scan a lot of prgrams and XP services at boot up.
Then you would want to get hold of an XP tweak utility, best one is Cacheman XP that you can find at MajorGeeks.com also.
Once Cacheman is installed and open the program you will see a tap in the program window called Tweaks. When you are in there, open the Help file and read the help associated with the Tweaks and you will see some good guidance on turning off settings available in buried locations of XP. The programs MS now downloads for you like Malicious Software program will slow down your boot speeds too.
XP is notoriously slow at booting and yours is about 30 outside the average bootup times you should expect.
Posted on Jun 23, 2008
    Genius:
  • 2,785 Answers
From msconfig you disable all startup item and restart.Also you defragment your hard drive once in a month and use a good antiviruse and scan your pc at regular interval
3 Suggested Answers
askanything
  • 151 Answers
SOURCE: Windows XP Unusually Slow Startup
1)Go to start menu 2)Then go to 'RUN' and write MSCONFIG in its textbox. Then click on Startup tab and disable all option. 3) then restart ur pc.
Posted on Sep 23, 2007
pagebor
  • 2785 Answers
plz go to msconfig and disable all item except the antiviruse in the startup tab, then go to my computer propeties ,click on advance then click on performance then select adjust for best performance(visual tab) then go to advance tab and change the page file to 1024 for both(min and max) then do a full scale system scan for viruse
Post your findings
Posted on Apr 28, 2008
Installed win 7 but want restore to xp
To reinstall win XP from usb flash drive you need WIndows XP cd, 1 gb flash drive and Novicorp WinToFlash. Download WinToFlash to your computer and follow instructions to transfer Windows XP from cd to flash drive, After that boot your notebook from usb device and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon" then install win xp normally, but format C partition. After first start of your notebook boot again from flash drive in "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon". Now windows is starting, go to start/my computer right click on it and go to properties in this windows go to advanced tab and there go to startup and recovery, click on settings, in new window go to edit tab and in new window change the line "multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP" /noexecute=optin /fastdetect" after windows XP write the type of your XP Professional, Home Edition, or Media Center. Now you can remove usb flash drive and boot normally from hdd.
Nov 12, 2012 | Advent 4211c Notebook
How do I change the default program on my startup. Microsoft updated it to their media center. And how do I change my starup programs. windows XP
You can check, remove or disable your system start-up programs with Autoruns from Sysinternals. To change a specific startup program (ie a media player) with something more suitable for your needs you should check the program's configuration to look for a "run at the startup" sort of option.
Apr 29, 2011 | Microsoft Windows XP Home Edition
I start up my computer and i get a black screen that says "NTLDR is missing Press Ctrl+Alt+Del to restart" at the startup screen pressing f10 doesn't bring up system recovery and I don't have...
what is the model of your computer,? if the recovery software is in a hidden partition there must be a way to access it from boot, otherwise, you will have to buy a windows disk and reinstall windows.
Feb 05, 2011 | Microsoft Windows XP Media Center Edition...
I want to know that "is how many Windows XP version is publish So far"? any one answer detail i know only 2 one is HOME edition and 2nd is Professional " IS it ???? what about Media Center Edition...
to your amasement one answer is 8 versions
Windows XP Starter Edition
This edition is aimed for first-time desktop PC users in developing countries. This edition can only run three applications at once.
A version of Windows XP for home users. This edition replaced Windows 9x/ME
Windows XP Home Edition N
This is a special edition of Windows XP Home Edition for the european market
without media player
A version of Windows XP for both businesses and home users. This edition replaced Windows 2000 Professional
Windows XP Professional N
This is a special edition of Windows XP Professional for the european market without media player
A Windows XP version for Media Center PCs with an easy to use interface and remote control support
Windows XP Tablet PC Edition
This is a Windows XP version for Tablet PCs with pen and speech capabilities
Windows XP Professional x86 Edition
This edition is for AMD64/EMT64 64-bit processors
guess you didn't knew that.
nice question and thanks for using fixya.
Please vote if satisfied.
Jun 03, 2010 | Microsoft Windows XP Professional for PC
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
My screen shuts down automatically
hiiiiii friends
some virus on your pc .....remember you format it total driver........
Nov 10, 2008 | Microsoft Windows XP Media Center Edition...
Booting
the following id taken from my own XP media centre laptop.
line 1 [boot loader]
line 2 timeout=30
line 3 default=multi(0)disk(0)rdisk(0)partition(2)\WINDOWS
line 4 [operating systems]
line 5 multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
ignore the "line 1,2,3 etc" I added them for clarity the formatting in this answer pane messes up the last line.
also before you get to edit the start up file make sure that the default operating system listed is the sae as line 5 starting from the "
hope this helps.
Nov 08, 2008 | Microsoft Windows XP Media Center Edition...
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
Post your findings
Apr 28, 2008 | Microsoft Windows XP Media Center Edition...
possible that the virtual memory is fragged. try disabling the VM then do a disk error check followed by a disk defrag then re-enable VM.
Sep 09, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows XP Professional Logo
980 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
