Question about Sharp Office Equipment & Supplies
How I CAN CANCEL CODE U2 in sharp arm451n - Sharp Office Equipment & Supplies
  • 148 Answers
This resets the code
Sim 16 sub 0 Used to cancel the self diag "U2" trouble. Cancel Trouble Error
SIMULATIONS
1. Entering the simulation mode
Enter the copy mode and perform the following procedures.
[P] [*] [C] [*] [Main code] [START] [Sub code] [START]
2. Switching the simulation mode
Press [USER SETTING] to return to the code entry screen.
3. Canceling the simulation mode
Press CA key to cancel the simulation mode.
You may need to have a tech look at this.
Hope that helps
Posted on Jun 23, 2008
Dear sir,
I am very grateful to you for your letter and I hope continued in the future with you,
Thank you for everything.
hussein al-hadrawy
Posted on Jun 25, 2008
Mx-m354u sharp copier please tell what is the problem error code u2-23
its a PWB SRAM memory individual data check error try to use sim 16 to cancel error or replace the PWB.
Oct 31, 2016 | Sharp Office Equipment & Supplies
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Oct 18, 2013 | Sharp AL 1631 Copier
Sharp error
What is the error code you are getting???
Jun 07, 2013 | Office Equipment & Supplies
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
U2-40 error code on AR5012n
U2-40 Content CRUM chip communication error.
Detail
An error occurs during communication
between the MCU and the CRUM chip.
Cause
CRUM chip abnormality.
Developing unit disconnection.
MCU PWB abnormality.
Check and remedy
Replace the chip.
Check installation of the developing unit.
Sep 07, 2010 | Sharp AR-160 Copier
CODE U2-23 sharp please tell what is the problem ? thanks
SRAM trouble or
Control circuit runaway due to noises
ICU PWB SRAM access circuit trouble
Use SIM16 to cancel U2 trouble.
P<interupt> C <interupt> 1 6 Start
Jan 11, 2010 | Sharp AR-M455N Copier
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316 E photocopier error clearing
try to cancel it by pressing: #-interrupt-C-interrupt simultaneously, then when the panel goes off input 16 then press the COPY KEY <> The machine will restart automatically. if U2 still remains.. try to replace the mainboard.
Jun 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp error code U2
you can get rid of this u2 by pressing buttons as follows: # , interrupt, C, interrupt sequentially. then enter the no. 16 and press the start button. good luck
May 15, 2008 | Sharp AR-207 Copier
356 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
