Home | Canon | PowerShot A620 Digital Camera | Adjusting date and time
Canon PowerShot A620 Digital Camera
Problem for Canon PowerShot A620 Digital Camera
By ddavid88 on Jun 23, 2008
Hi.
I have a problem with adjusting date and time on my PowerShot A580. It's a completely new camera with new batteries, but it often asks to adjust data and time again (though I did it many times before it). When I adjust it, it stays in the memory for a few minutes (I can push the on/off button without needing to adjust date/time), but it asks adjusting again. I have no idea what the problem can be, because the machine doesn't always ask the adjusting.
Can anybody help me?
Thanks in advance!
Comments:
Jun 23, 2008
- If the date battery has a code CR1220, then I see it. I tried to fix its position in the holder, and it seems it works! Thank you very much!
Clarification Request
Posted by old marine on Jun 23, 2008
Did you put in the date battery in your new camera? It fits in a holder right next to the regular batteries. If so, you may need to put in a new date battery, as this is what 'powers' the clock in the camera.
Same Problem
Jan 07, 2009
-   Thanks for this answer, you saved my life. My camera was driving me nuts asking for date reset every few minutes! -   Guest
Solution #1
posted on May 12, 2009
Not Rated)
smartr10U
Rank: Guru  Canon Expert
Rating: 87%, 475 votes
According to Canon, the backup memory lithium battery (interal) recharges off the main AA batts that you put in... the manual says it takes about 4 hours to charge this battery.
When not in use, leave the AA batts in the camera .. see if this helps keep the date/time memory!
K
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A620 Digital
Questions and Unsolved Problems for Canon PowerShot A620 Digital
Do you recommend Canon PowerShot A620 Digital Camera?
Answer
Answer
My camera has a white speck of dirt underneath the first lens, and does interfere in pictures and... (More)
Answer
camera used in light rain, flash banged and quit, works otherwise is it possible to fix myself with... (More)
Answer
the date stamp is turned off and on the menu screen I cannot scroll down to the date stamp to check... (More)
Answer
Hi, I know I had voided my warranty, but it has long been over anyway. I had open up the side of the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A620 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
