Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Coffee machine faults
I have had this machine for four years and have had it back to saeco 4 times for different issues, this time the fifth time the repair agent said it needed a new motor as it could not drive the brew unit all the way and we aggreed, then they rang us and said a transistor on the power board has now popped.
I told the service agent not to worry as he wanted 600 dollars for repair and i will repair myself.
Why are these machines so unreliable and why do saeco choose dud agents for repairs.
  • 41 Answers
Change the TIP33C transistor as this is a common failure , it controls the voltage to the brew unit motor. Very cheap to repair. Cheers
Posted on Oct 31, 2011
  • 2,039 Answers
Saeco is not what it used to be even if you find a board our motor its gonna expensive part think twice me i prefert the older vienna and you find part easy good luck pierre
Posted on Jun 24, 2008
Saeco 6
If the unit isn't that old try using vinegar straight in the machine run it though more than once if necessary. The problem is that the little boiler inside builds up with calcium and scale from water that is too alkaline or hard. Once you have run the vinegar through a few times then run water through 4 or 5 times so you don't get the taste of the vinegar.
Sep 03, 2014 | Saeco Xelsis Digital ID Automatic Espresso...
My Saeco xsmall plus espresso machine is flashing red light on it
Owning this machine for nearly five years, all I can say is that it is an example of problematic engineering. It does not except dark roast some of the time, and if it is very well roasted it won't accept it at all. As the machine is fully automatic, there is not much you can do but roast the coffee to a degree that will be accepted by the machine. IMHO this is an unacceptable decision made by engineers and Saeco should address this issue.
Nov 04, 2012 | Saeco Coffee Makers & Espresso Machines
Descaling
Ok guys this is my own opinion on descalling and I have to tell you firstly I have been repairing saeco machine for over 8 years so I think I know a bit about them by now. Scheduled Descalling to me is a waste of time and money, now I'M NOT saying to "never descale your saeco" but when that descale light or word comes up on your machine it does not necessarily mean your machine needs to be descaled. Your Saeco machine DOES NOT have a magical sensor inside that tells you there is calcium build up inside the boiler. All Saeco machine use a timer device built into the Electronic main board. As a pre set number of coffee's are made, Saeco has set a timer to bring up either a light or Symbol on screen to tell you your machine is in need of a descale. Now with different countries , States and living conditions not all water outlets consist of the same water purities, so how can Saeco say at a certain time your machine needs descalling? . I can only go by experience where I repair machines in Australia (Melbourne) and I have had many machines fail due to being constantly descalled. How many of you have been having a good run from your machine until the day you thought you had better off descale your magic deluxe as it hadn't been done in a while. Upon descalling the machine you hear and see water leaking from the unit and Bang , the machine stops dead , or if your very lucky you shut the machine off just in time before the circuit board gets wet and you send the Deluxe to Saeco and now your up for a new boiler and service.
What had happened is that in time the seals of the boiler have broken down and the calcium lining the boilers internal walls have been sealing the boiler from leaking. Upon cleaning the boiler , calcium is removed and the seals don't hold and you know the rest. I have personally given a machine to a family member and told them never to descale just to see what happens ( will the boiler go , or water stop flowing due to blockages? ) I can honestly tell you that this machine was made in 1996 and I had replaced the boiler 8 years ago , to this day the machine has not missed a beat and no leaks on boiler. Ah they hardley use it I hear you say , quite the contrary , Italian family, machine used every day and even taken once in a while to their local social gatherings making coffees for over 30 people. I also have a customer who every so often after 2 years will come back for a new boiler fitted ( machine used in pannel beating shop ) I told him to try not doing any descaling until he could see any water flow restrictions. It's been over 3 years now and I havent seen the machine back yet but I do time to time come across him and ask how the Saeco is going , he says "all is well". Now not doing a descale at all is madness as I have had many blocked or semi clogged boilers due to high calcium deposits ( expecially around the beach coast areas ) But if you feel that your machine is pumping a little less water and the brewer is clean form any blockages then a well deserved descale is probably needed. With older machines you only need to reset the descale light or display if not needed. With other types like Saeco Incanto you need to only go through the descale process without the additive or cleaning fluid introduced into the water tank and decsale will reset.I hope I have shed some light on this issue and I'm not trying to say Saeco are pulling the wool over your eyes when it comes to descaling. I am going by my experiences only and what I have seen during my time with these machines. Enjoy your Coffee.
Mar 12, 2010 | Saeco Magic De Luxe Espresso Machine
My saeco machine is not functioning in the right order, it grinds after it makes the pad. So I first hear the clicking sound (meaning it is making the pad first with old grinded coffee) and then it grinds...
HI
Read the first then go to the bold letters.
To program your Magic Dlx: Press and hold the steam and small espresso buttons at the same time, then push the energy saving button (top right). Water Hardness. The large coffee button programs the water hardness. Press the button once and you will have one light in the top row, left side. Press it again and you should have two lights lit. Press it three times and you have three lights lit. Four and you have four lights lit. Press it a fifth time and it goes back to one light. Each light represents your water hardness. So if you have a water hardness of 3, press it until you have three lights lit. Press the energy saver button to exit the program and save your hardness level in the machine’s computer. It will now tell you when you should descale your machine. Pre-infusion. Press the medium coffee button to activate and you should see the light come on. Press the button and turn the light off to deactivate the pre-infusion. Pre-grinding. Pre-grinding is turned on with the cup warming button. When it is lit, the pre-grinding is on. Press the button to turn it off.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Saeco Vienna Coffeemaker won't heat/reach 'ready' state
May be time for a new machine.
Its either the electronics or the boiler, or worse. Both.
Vienna's have a typical life expectancy of about 4 to 7 years. 10 years is very commendable.
If the electronics and boiler are both bad it will end up costing almost as much as purchasing a new machine.
Aug 08, 2009 | Saeco Vienna De Luxe Espresso Machine
This is the second time I've had electronic problems with my semi auto solis crema. The first time we sent this to empire fulfillment & it took 8 months to repair. I live in Michigan. Any...
Find a gaggia or saeco repair agent in your area, the machine is similar, and they should have no problem helping you, or if you are up to it you can repair it, with a little help of course.
First what is the machine not doing?
Second you will need a long thin phillips screwdriver, and some long torx drivers.
Jul 16, 2009 | Solis Master 5000 Espresso Machine
Our saeco incanto turned off for no reason-won't come back on.
Push on the right upper side of the door and see if the light comes on?
May 18, 2009 | Saeco Incanto Classic Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
289 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
