Question about Epson AcuLaser C900 Printer
C900 Colur print problems
I have had a new PCU all colours are relatively new half full, I have noticed a gradual degrade of the red output, I have done a Epson test page there is a reduced blue & red and no yellow what so ever yellow appears on the toner when removed
Print a self made test page in word, a bar of bright yellow, bright cyan, bright magenta (almost pink) and black.
You might find one is completly missing, if so its a faulty toner or maybe the pull strip did not rip out correclty.
Posted on Jul 08, 2008
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
I have a Gestetner DSc38u and when I print colour I get a 'red'/'pink' line about an inch from the top of each page. Any suggestions?
If the line is only red or pink, it is most likely caused by the magenta PCU. Replace this PCU and your problem will go away.
Occasionally the magenta developer unit can cause a red or pink line, but the problem is more than likely from your magenta PCU. The PCU is easy to replace, and instructions will come in the box if you order an OEM replacement unit.
Jan 22, 2011 | Ricoh Aficio 3800CMF Laser Printer
My Ricoh Aficio SPC811DN printer keeps asking me to replace my PCU colour all the colour carteridges are over half full what do i have to rplace
The PCU is the drum unit. There is one for each colour (C,M,Y & K). Each PCU has a 'life' and the machine will ask you to replace it when it has reached the end of its expected life. The PCU life has nothing to do with the amount of toner that you have in the cartridges and they need to be changed independantly.
Jan 18, 2011 | Ricoh Aficio SP C811DN Laser Printer
The Bizhub C351 is printing the colours wrong the red and yellow comes out pink and a yellow smudge line prints on the top of every page how do i fix it?
print off halftone for each colour
utility/counter,metercount,stop.0.0.stop.0.1test mode.halftone.cmyk start.this will print off each colur, the "failed" one will be easy to see
Jun 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Colour smudges
try cleaning the print head and also see this post on the photoconductor
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Jan 23, 2008 | Epson Aculaser C1100 Printer
Colours printing really faint
dear sir you should check the colour mixing detect sensor
Sep 26, 2007 | Epson AcuLaser C900 Printer
Colours not printing correctly
please check the charging roller of your new cartridge
Sep 07, 2007 | Epson AcuLaser C900 Printer
Wrong colour
This could one of a few fairly major problems. The easiest way to track down the fault is start by replacing the consumables - make sure you install them in the correct positions - it is possible on the C1100 to put them in the wrong places!! Change the toners first. Most importantly the magenta and yellow. Print several pages. Use MS Paint or similar to create a page with all four component colours on (cyan, magenta, yellow and black)in large blocks (see image below) and print them full page. Now look at the print and see if any one colour is missing or has reduced density. If you have a spare PCU you should but that in next. Let me know what the print outs look like and we will progress to the next step.
Aug 13, 2007 | Epson Aculaser C1100 Printer
Epson AcuLaser C900 Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
