Question about Garmin eTrex GPS Receiver
Getting to see the UTM coordinates of where I am on the gps screen
I am having problems on the above. I dont seem to see in the manual how to display the location coordinates
  • F5ZZ
    F5ZZ Jan 11, 2014
    Yes, it's not easy to read UTM in real time. I finalyze a project of permanent reading (on may car) the UTM position with a raspberry Pi : GPS -> MNEA ingest -> convert UTM -> display on a 16 7 seg digit (with an Arduino driver). It could be enougth.
The solution is in the manual but however it is not given the prominence it deserves. It is talked about in passing and yet it is the most important thing GPS users need. One goes to the Pointer and uses the scroll up and down keys to get the coordinates aprt from other things like bearing, elevation, sunrise or sunset time, trip odmeter etc .
The manual should clearly show this prominently. I gave this GPS to 4 people and the manual and all failed to figure this out. This shows the instruction is not user friendly. The Old Garmin GPS would lead you straight into coordinates and the accuracy reading on the same screen display and this was simple.
thanks
Posted on Jun 24, 2008
On google plus it allows you to share your location with whom ever you choose, so my husband and I share our location with each other, but for some reason his is always wrong, and it always shows him in...
Hi Brenda
You need an App that will give you your current GPS coordinates.
Install an App Like MotionX or similar. Check the Latitude & Longitude or Better still the UTM Easting & Northing (same thing but UTM is the new digital coordinates & is easier)
Compare one phone coordinates with the other phone.
they should be almost identical if your in same location.
Otherwise check your phone SETTINGS for GPS & how it's set up.
Even a standard Garmin GPS tracker (which I use for prospecting) can be set fro the wrong side of the world. Usually its set for WGS 84 or 94 & UTM. I have seen people set up for the northern hemisphere when they are in the southern hemisphere.
Also, you said that your husbands settings never change. Well... it's GPS either turned off or broken.
I also use my "Find My Phone" App to check on the wife.... and she's on her way home... so GoodLuck
Cheers
Trevor
PS
Poor choice of Brands.... but thats another story.
Aug 06, 2014 | Cell Phones
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
Cant enter the coordinance to go to reefs offshore how do these things work
User Manual open the above link and go to page 22. It explains how to manually enter a waypoint if you know the coordinates. It also explains anything else about your GPS receiver. Good Luck, Have Fun, and be safe!
Feb 28, 2011 | Garmin GPS 126 GPS Receiver
Enter waypoints via computer keyboard
Install Mapsource from Garmin on your computer. It will allow you to enter your points then upload via serial or USB.
Jun 15, 2010 | Garmin Gpsmap 76csx Handheld Gps
How do I use coordinates? I entered map coordinates and it took us to the wrong place.
Some Tomtoms can use latitude and longitude coordinates. They refer, of course, to points on the map.
To use coordinates on some tomtoms you tap the Browse Map option. A general Map of the route is displayed. The screen has three buttons at the bottom
  1. Options
  2. Find
  3. an icon for the point on the map.
  4. Done
Tap the Options button: The Map detail Preferences appears, offering the choice to put a check mark in POI, Favorites, images. At the bottom of screen you have 3 buttons : POI, Advanced, Done.
Tap Advanced: In thsi screen you can put a checl mar on Names, Markers, and Coordinates.
Put a Check mark on Coordinates and press Done, Then Done again until you exit all those options.
Now your tomtom is configured to display coordinates. Be aware that GPS technology was created for military purposes and its civilian uses cannot be expected to offer pin point accuracy. It took an act of the US president to allow its use for civilian localization.
When you plan a route you can use longitude and latitude. Here is the icon you should like for.
Dec 30, 2009 | Tomtom ONE XL GPS
Can I manually enter gps coordinates into uniden trax_430 gps
The seller LIED! here is the review where it says this feature was disbled.
Both the Trax 436 and 430 have a 4.3 inch widescreen making it easier to see the navigation display than with smaller 3.5 inch units. As there is only a single button (on/off) on the device, all data entry through pressing the touchscreen display. There is predictive text to help with some entry fields. One of the interesting design features alluded to is Safety Mode which disables the touch screen above 10km/h to ensure the driver has their attention on the road ahead.
A second of the interesting design features noted is the simple and advanced navigation interface modes. It makes a lot of sense to disable some more advanced functions, such as navigation to a GPS coordinate, in order to make a simpler, less cluttered menu structure for the average user. Incorporating text-to-speech capability, the Trax units’ voice navigation instructions include street names making it simpler to check one is on track without having to glance away from the road to the GPS unit display.
heres the link for more info
heres the link
http://gpstekreviews.com/2009/09/02/uniden-trax-436-and-trax-430-gps-43-inch-auto-navigators-review/
Perhaps return it for a refund on receiving misleading information.
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Uniden TRAX-430 GPS Receiver
Navigation
You'll have to do this online
http://www.cellspark.com/UTM.html
Sep 06, 2008 | Garmin eTrex GPS Receiver
Toggling between lat/long and grid references
I eventually solved the problem by firstly doing a restoration of default settings. This allowed me to toggle but it was between two different presentation styles of latitude and longitude. To restore the grid co-ordinates option I went to main menu, the Setup, then then toggled to location and re-selected UTM UPS as the location format.
Apr 27, 2008 | Garmin GPS 72 GPS Receiver
Loading gps marks e Trex hand held yellow
Your manual tells you how to enter waypoints
http://www.fixya.com/support/p237226-garmin_etrex_gps_receiver/manual-14514/page-16
Mar 29, 2008 | Garmin eTrex GPS Receiver
Garmin eTrex GPS Receiver Logo
542 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
