Question about IBM NETVISTA M42 - P4 2.4GHZ/512KB 256MB 40GB 48XCD DESKTOP(4X3) SOUNDMAX 845G ENET (830342S08)
No sound but it beeps
I have lost all sound from computer except for a beep. I updated my realtec driver, but it doesn't work.
I had soundmax that was deleted and I really don't know which problem is causing the sound loss.
Obviously the speakers still work because of the error beep. The little speaker icon on my lower toolbar is gone as well.
How do I fix this problem
  • sassou Jul 11, 2008
    i tried to find my driver but itn was deleted from my computer
    Genius:
  • 2,785 Answers
Plz reinstall your sound drivers from the mother board cd,if after installing also no sound then you post back with your motherboard make and model no,
Posted on Jun 23, 2008
Acer aspire long ans short beep error
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive IDE SATA
Make sure they have a secure dust free connections if its a flat 40 pin ide it will be the first to fail
Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it.
Restart your computer the found new hardware wizard should activate
A computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function.
Make sure all leads that are attached to your drives dvd\cd and floppy drive have secure Make sure the connections and are not faulty or just replace them they could be faulty
A computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error.
Also check the Keyboard for secure dust free connection ps2 and or usb.
Click start control panel administrative tools computer management device manager scroll through devices if you see a yellow Question / Exclamation ? ! or a Red X a new driver will need to be installed / updated.
Right click to update driver.
If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
This is a free driver solutions.
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Dec 01, 2012 | Acer Aspire M1202U1850A PC Desktop
I have no sound and the realtec audio driver is not showing up in my device manager. I've tried everything..help
It isn't showing up because it doesn't belong ther. Vaio.com/support/drivers/download and get the right one.
May 22, 2011 | Sony VAIO VPCEA36FM/W Laptop
Volume icon lost from my toolbar
I thing this problem because a SoundMax driver conflict with windows vista.I thing you should update your SoundMax driver (if you have) or if you using the old AVG,upgrade it.
May 09, 2010 | Microsoft Windows Vista Ultimate Edition
I bought a used GX520 and the volume does not work. There is no volume icon on the lower right corner. Under sounds and audio devices it says ''no audio device'', and I can't change anything. I own another...
sounds like ( no pun intended) your missing the audio drivers or controllers--right-click on MY COMPUTER then PROPERTIES then HARDWARE then DEVICE MANAGER and check if there are any yellow or red "X"s next to anything (you sound driver) right click and select update driver (you need to be connected to the internet)
Sep 17, 2009 | Dell GX520 PC Desktop
I have an HP Pavillion m9600t with Windows 7. Sometimes when i try to play games the sound crackles and progressively gets worse until the computer freezes. Any thoughts?
This seems to be a problem more with Realtec onboard sound than with a stand alone soundcard. You can try either updating the Realtec driver or using the generic windows driver and forget using the realtec functions. But with my computer the only true fix was to disable onboard sound and install a soundcard. Hope this helps.
Sep 06, 2009 | HP Pavilion Elite M9600T Desktop PC with...
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Usb speakers
You need to install the sound card drivers for your PC, check the cds / software that cvame with your PC, or go online to PC manufacturer's site to download drivers for your system.
Apr 27, 2008 | Audio Players & Recorders
I get a loud beep on my laptop but cant hear anything else
There is a beep system in all PC's
One quick been means the computer is OK when starting.
one long continuous beep is defined as :
' Power Supply or System Board / Keyboard stuck '
Note: Alternately it could be a Memory module
However it's more likely that it's the above
If you check those two things, you are likely to find the culprit.
If not, you need to post your BIOS and
Feb 20, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
158 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
