Media Player 11 Installation
Sir,
I need you advice to how i install medai plyayer 11 in my PC. It's processor is 2600+ and moherboard is Asrock K8 sereies. It has 640 MB ram and 80 GB HDD.
    Brigadier General:
  • 3,614 Answers
Http://www.microsoft.com/windows/windowsmedia/player/faq/installation.mspx
Posted on Jun 23, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Need an onboard ethernet driver
You can download the required drivers from:
http://www.asrock.com/mb/download.asp?Model=K8%20Combo-Z&s=754/939
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Sep 03, 2009 | Asrock K8 Combo-Z Motherboard
Have video but no audio when playing dvd movies in wmp 11
Solution:
Well i could recommend another free video player instead of Windows Media Player 11. In this case, try installing Real Alternative, VLC, GoomPlayer all lf them support DVDs format.
I recommend Real Alternative over all 3 of them, to get it go here:
1) http://www.videohelp.com/tools/real_alternative and click on the "Download (mirror)".
2) after download is complete start the installation make sure to UNCHECK the following checkmarks during installation: Active X, and pluggin for firefox/opera/chrome/etc. you can leave the rest of the installation as default and click next all the time.
3) whenever you want to play a DVD close WMP 11 start Media Player Classic (installed during the real alternative installation, there should be a shourcut icon on your desktop for Real Player Classic now) on Media Player Classic go to File>Open DVD and you should have picture and sound.
Another extra side note of Real Alternative is that you can also play real media files (.rm, .rmvb) without having to install the nasty Real Media Player application
Hope this helps.
Dec 22, 2008 | Dell Dimension 8400 PC Desktop
Davy
What verson of Windows Media player have you got on your pc?
Find one with version 9 install the creative software and then try the reload of the firmware .Zen has problems with windows medai player 10 - 11.
Jul 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
USB Power Issue with ASRock K8 Combo m/b
Are you plugging in to the usb ports on the MB, or on the case?
Jan 14, 2008 | Asrock K8 Combo-Z Motherboard
Installation
Try to use Windows Media Player 10 or 11 Try that
Dec 22, 2007 | Creative Labs ZEN V Plus MP3 Player
Not detected by computer - cannot recharge battery
yay I found a solution! so I kept getting the error about an MTP device, so I did a big search. I am running vista on a 32 bit processor. what you need to download is the MTP installation programme from windows. so click on http://support.microsoft.com/kb/939211
and then just select what processor speed you need. should do the trick! I also downloaded http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en initially, but it didn't appear to work. hope that you all get to the bottom of this frustrating problem :)
Dec 18, 2007 | Samsung YP-U3 MP3 Player
Computers & Internet Logo
David Payne
David Payne
