Question about D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater
DLink Wireless Extender
I have a ProLink Wireless G ADSL Router Model: H9000G and I need to the wireless coverage in my office abt 20 mtrs. Do you have any suggestion to solve this problem.
Rgds ~ rosie
  • 550 Answers
  1. move the router,
    the router can be anywhere, as long as it is connected to the modem
  2. reorient the antenna,
    its surprising just how much difference changing the antenna direction has.
  3. ensure the router is broadcasting at 100% power in the router settings page
might not solve the problem, but have worked in the past
Posted on Jul 17, 2008
Low signel strength
Common with single antenna routers and adsl/router boxes, i use a zoom x6 adsl with wireless and i was having similar problems , it also has a single antenna so i disabled its wireless feature and got a linksys rangebooster router dedicated to my wireless needs, has good range and its durable, Im basically suggesting that you get another wireless router with dual antennae and use that for your wireless needs, hook that up to your DLINK modem via ethernet cable and disable the dlink's wireless feature...Hope this helps..
Oct 27, 2010 | D-Link DSL-G604T Wireless Router
Opening a port for webcam
hi friend
here is the spcifaction of ur router see it
Apr 07, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
How to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
Apr 03, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Wireless g range extender
Hi there ....
before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
1) either which, please do verify your wireless settings of your DLINK router
-- the network name or ssid
-- security if you enabled any on your router
-- wireless channel
-- please check the default gateway of your router if it is 192.168.1.1
** please take note also that the best location for your expander would be inbetween your router and your computers
2) once you have gathered the wireless settings
-- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
Thanks and good luck!
Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
D-Link DIR-655 as Wireless Extender
you need to run "cat. 5-e" cable from the first router to the other.
if this is not an option, purchase a range extender box, which communicates between the two routers.
Apr 26, 2008 | Computers & Internet
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Using a dlink extender
I'm assuming you mean a wrt54g, if that's the case look on the bottom of the router and see what version it is. If you have a ver. 1, 2, 3, or 4 then you don't need an extender. you can flash a 3rd party firmware into that router and turn it into a super router. If you are interested, then leave a comment and i will tell you how to do this. An extender will just cut your broadband speed in half so I would avoid that if possible. Let me know.
Sep 15, 2007 | D-Link 2.4GHz Wireless g Laptop PCMCIA...
D-Link AirPlus G Wireless Range Extender DWL-G710 (dwlg710) Repeater Logo
375 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
