Question about Casio Exilim EXZ75 Digital Camera
Battery charger(BC-11L) Battery charger not holding charge.Red light blinking
  • 9 more comments
  • robc8 Jul 20, 2008
    battery doe snot charge and the red light blinks in the charger any one know the problem?
  • Anonymous Jul 29, 2008
    same problem...i've been using it over 1 1/2 years now...
  • Anonymous Aug 15, 2008
    says battery problem and flashes in charger...doesn't hold charge. 1 yr new.
  • Anonymous Aug 30, 2008
    Same problem. I left the battery in the charger all day and the red light just kept blinking. I didn't use my camera for a couple of days then when I tried to turn it back on it wouldn't turn on so I figured it was the battery. But now the battery won't charge at all.
  • terrilynn_86 Oct 09, 2008
    charger not holding its charge. red light keeps blinking
  • Gus Garcha Oct 10, 2008
    Same blinking when charging the battery.........Camera wii not turn on....
    Battery don't charge....Charger red light blinks out of control......
  • Anonymous Oct 11, 2008
    Happened to me twice. I called Casio and they replaced me a new battery. Now the new battery is blinking too.
  • Anonymous Oct 12, 2008
    The red light continues to blink i haven't used my camera in a few weeks but the battery is supposed to last a long time. How do i fix it?
  • eunancorr Nov 21, 2008
    Have CASIO EX-Z8 with BC-11l charger and NP-20 battery.
    The battery fails to charge - the charger light blinks red. I though the battery was faulty and so replaced it, with the same problem.
    However, I brought my Camera to a shop and they inserted a different battery and the Camera worked fine.
    Is there a fault with the BC-11l charger - and are there any solutions?
    Many thanks,
    EC.
  • martha bohling Nov 21, 2008
    I had the same blinking red light when i tried to recharge the battery. If you call Casio they will probably send a new battery to you free of charge. They didn't even trouble shoot the problem and very few questions. I would guess this problem has happened with other models since they use the same battery.
Battery charger will not hold its charge. the red light keeps blinking
Posted on Oct 09, 2008
  • 34 Answers
Your Battery is faulty and requires replacment.
Depending on where you are and if it is still within the new warranty period or not depends on how long or how much it will cost to replace the battery. Call the Distributor for Casio in your State or Country and they may even send you one out Free Of Charge.
Posted on Aug 21, 2008
Why red charge light keeps blinking?
Is your battery a LiPo (Lithium?) If so ... These special batteries are charged by a computer circuit that holds the charge amperage constant and adjust upward the charging voltage until the required battery voltage is reached. At this time the charger hold a constant voltage and decreases the amperage as the battery capacity is "topped off". the charger circuit charges the entire battery at once but monitors each cell (cells are about 3.7 volts each) and controls the charge so that all the cells are ballanced.
When one of the cells that makes up the battery starts to go bad, the ballance circuitry prevents over charging the others, so one weak cell hold all the cells back from full charge and better charger circuits will signal you with an led or such that the battery is' going' bad.
May 07, 2014 | Radio Shack Accurian LMD-5108A Portable...
Charger will not charge radio, has red blinking light
If the radio will charge on one charger and not the other, the one with the blinking light is bad or has a dirty or defective battery contact. Check your charger for debris and clean your battery contacts with a pencil eraser and try charging again. If this fails, replace your charger.
Best regards.
Jan 31, 2014 | Kenwood KSC-37 Replacement Charger for...
Bosch charger not charging
Its sounds simple but always worth a try, clean all the contacts on the charger, one will read the condition of the battery, If this is dirty, it may not be giving a strong enough signal to the charger and as such it will interpret the battery as faulty.
Dec 06, 2013 | Drills
The light on my Sony BC CSD battery charger is blinking. Please, please, please help me and tell me what it means.
That usually means it is charging a battery.
Do you have a battery in the charger?
If so, put it into your camera and see if it is fully charged.
If not, replace it i the charger and leave until blinking stops.
If this does not happen within 12 hours the battery is probably defective.
Jun 24, 2011 | Cameras
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Can i charge the camara via usb port
You cannot charge your battery using a USB port. You must use the Battery Charger (BC-11L) that came with your Casio Camera.
Nov 13, 2009 | Casio Exilim EX-Z77 Digital Camera
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Lithium ion battery won't charge
known issue, battery needs to be 'shocked" back to life. Here's the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Nov 04, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
Battery will not hold a charge.
Casio says:
Red blinking light = defective battery
No flashing light = possible defective charger.
What you can do is send all your stuff into casio and they will test everything for you and see what they could replace for you.
Sep 03, 2007 | Casio Exilim EX-S600 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
650 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
