Question about Konica Minolta magicolor 2400 Laser Printer
Toner Not Installed - After replace black
After replacing the Black toner cartridge in the Konica Minolta magicolor 2530 the printer flashed up not genuine toner cartridge, then displayed Yellow not installed , Cyan not installed, Magneta not installed.... it thinks that no toners are installed. As it said the black was not a genuine cartridge i put the previous empty black back in.
The printer still displays that the color toners are not installed. It will not rotate the toners (only when you slect replace a toner) otherwise on its own they rotate, it doesnt say black isn't genuine anymore but still won't let you print. And says the toners are not installed, but they havn't been moved. The colors are full.
  • dualfever Jul 02, 2008
    This worked, after the chip had been cleaned the other cartridges were detected and the black still printed out although it said it wasn't genuine. thanks.
  • Anonymous Mar 29, 2014
    I changed the k toner and the display keep saying no toner k instaled
    Problem Solver:
  • 5 Answers
This is actually a desigbn fault on the magicolor printers. Underneath the toner rack is the 3 pin chip reader - normally white and plastic with 3 metal contacts sticking out.
it is at the bottom of the printer so very often toner drops onto it and the sensors dont work, it also takes a bit of a beating as the cartridges rotate. Its very easy to replace - but you need the part,
Minolta should have put it at the top rather than the bottow where it gets covered in dust.
these guys helped me a lot
http://www.zinetic.co.uk
Posted on Feb 22, 2009
    Champion:
  • 214 Answers
Pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Posted on Jul 01, 2008
In fact from the menu (I have magicolor 2530 which is a new declination of 2400W) I was not able to remove all cartridges: after having one taken the printer does not want to rotate anymore to access others. I made them rotate manually pushing vigourously the rotating system but I believe it is not a good solution. After that I could access the sensor and clean it and it works. I discovered a better solution: After removing the drum, without removing the cartridges the sensor is half vesible: we see on the right just beneath the cartridges a white plastic square and we jave just to intruduce a little brush or a bit of paper towel folded in four over it to clean it. Jean-Louis Ramel
Posted on Apr 18, 2009
I have a line running through my pictures. it doesn't matter what picture i print, i get the line
Well, there's bad news and then there's worse. Hope for the laser lens. Hope it's not the drum. By the book:
Abnormal
areas (white,
black, or
color) appear
in a regular
pattern.
The laser lens is dirty. Clean the laser lens.
A toner cartridge may
be defective.
Remove the toner cartridges with the
color causing the abnormal image.
Replace it with a new toner cartridge.
The drum cartridge is
defective.
Remove the drum cartridge and check
for damage. If it is damaged, replace it.
Mar 30, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Jan 12, 2010 | Konica Minolta Magicolor 2450 Printer
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
I have to change black toner in my Konica 2530DL. Have never done it before. No one kept the manual and I can't figure out how to get the black toner cartridge out!! Help please.
press the up/down buttons on the printer till you hit menu special pages; press menu select button
press > arrow until you hit menu engine; press menu select button
choose engine replace toner; press menu select button
choose color to change and it will autorotate so that you can pull CMYK catridge out
Jan 20, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Magicolor 2400W error
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
Jan 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Drum cartridge
just open cover turn the toner rack if needed and replace the toner.
in right there is a black button, what is pushed down with the cover, you can push it down with pen or something, then the rack rotates easy. be sure to turn off the printer first
Jan 18, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
1,260 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
