Question about LG RU-27FB30C TV
LG CD20F69M TV Problem
Not getting luminus signal
I have an lg tv model 37LC2DB - EC I lost all my channels and can not auto programme so I did a factory reset now it says not programmed how do I get my digital TVs channels back
lg tv factory reset, not programmed? ' Yahoo Answers
Sep 21, 2011 - I performed a factory reset for my lg tv like I was told to do by the ... to get set for digital and now it keeps flashing not programmed anyone know ...
In my lg smart tv showing not programmed how to program ...
My lg smart tv keeps saying its not programed it wont switch on .... And after all is done, then run Error Checking/Chkdsk using the instructions in the link below. How To Run ..... We got a new lg smart tv was up and running now says not programmedwhat to do .... I have tired Auto tuning and Factory resetting. but no luck.
LG TV Signal Diagnostics, factory reset and manual tune ...
? 25:30
Sep 29, 2011 - Uploaded by 1976stuart1976
LG TV Signal Diagnostics, factory reset and manual tune - Post Digital .... one the net ran for a bit and now its telling me im notconnected and I ...
Jan 20, 2016 | LG Televison & Video
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide -
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
My lg tv does not recognise antenna socket/signal.
Check 2 items before going any further:
-- Make sure you have a good antenna signal by connecting it to another tv set.
-- Make sure you've switched input source of your tv to RF Antennae.
If the steps above didn't help your problem in TV tuner (assuming you're getting signal from other sources, i.e. DVD, VCR, etc). Have the unit serviced.
Mar 29, 2015 | LG Televison & Video
Why does my LG tv seems like it need to warm up before it will accept HDMI signal?
Sounds like a capacitor fault. They can be intermittent when cold, but will work okay when warm. Eventually though they will fail.
This is your advance notice to get the set either repaired by the manufacturer or a local TV shop.
Sep 06, 2014 | LG 42LG50 42 in. LCD HDTV
22" Logic tv does not get a signal from arial
is it the is it the Logik L22FED12 22" LED TV with dvd Combo that is having the problem or the LG 32LD550 32 in. ??
Jun 01, 2014 | LG 32LD550 32 in. LCD HDTV
Is there a solution to get enable me to receive a digital signal with this tv
You will have to hook up a regular antenna to get digital TV signals.Then go to your menu and find auto search.This should scan and pick up your channels for you.You can follow this link and on page 44 of the manual,it will explain step-by-step. Good luck :)
May 27, 2014 | LG 37LC2RR 37 in. LCD TV
No signal from hdmi for LG TV (lg47lm7600).
Looking around I find that LG is known for this type of break. Unplug TV for 30-45 min, plug back in. The key is to discharge TV by doing so. I would bet that this is a design flaw or hardware anomaly. If this is the case, buy another TV and expect to get 4 years max out of it... Crappy manufacturing and design is most likely the culprit.
May 07, 2014 | LG 47LM7600 47" 3-D LED TV
Tries tv unplug,replug it back like about an hour later for the tv resetting itself back to the factory setting.Tries again,tv should be working.If still getting no power at all than the tv Tuner board is dead,because pictures freezing and dies completely is the causes so it is not power supply board problems.The tv Tuner signal board is the causes,that the board where the incomming broadcasting signal cable plug into it.Tries websites like, to buy a refurbish tv Tuner signal board for the replacement.
Feb 17, 2011 | LG 42LC2D 42 in. LCD HDTV
Screen suddenly went to complete snow no video or audio
Well the LG tv is not getting the cable signal.Unplug the cable box about an hour.Replug the box let the software to upgrade the cable box.The LG tv should get the signal back as normal.Not,than the LG tv Tuner board have problems it dead.Tries Websites like, to buy a refurbish Tuner board for the replacement.
Apr 21, 2010 | LG 32LG30 32 in. LCD HDTV
LG RU-27FB30C TV Logo
57 people viewed this question
Computer Repairing
Computer Repairing
