Question about Canon Office Equipment & Supplies
How do i set up wireless printing for my canon mp810 printer thanks
  • 3 Answers
You will need to put the printer on another computer and share it on your network. Or you can buy a usb print server for about $50 that will put the printer on your network. the main objective is to get it on the same network as your wireless access point.
Posted on Jun 23, 2008
Instead of using a usb cable, I want to print wirelessly from laptop or iPad to my Canon PIXMA MP810 Printer. I have a wireless router with spare ethernet plugs at rear. What are my alternatives ? for...
You could purchase a ethernet print server which will allow you to connect your printer to the router via ethernet cable. I recommend the TPLink TL-PS110U. I use this for one of the printers in my office.
http://www.tp-link.com/en/products/prodetail.aspx?mid=0103030802&id=194
Alternatively, you could purchase the TPLink
TL-WPS510U. This is a wireless print server. It will give you some freedom if you wish to locate your printer to somewhere other than beside your router.
http://www.tp-link.com/en/products/prodetail.aspx?mid=0103030801&id=181
May 07, 2011 | Canon PIXMA MP810 All-In-One InkJet...
CANON PIXMA MP810 PROBLEMS - Aghhhhh!! I can
Try this,
scan the document to the computer, then view it using a picture viewer.
You may see that the scan is faulty!
The printer may be printing exactly what it sees!
Mar 07, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Canon mp810 is not printing correctly
Brand new cartridge or refilled one? If refilled cartridge, just wait for 30 minutes after refilling and use good quality of ink. It's caused by bad ink flow. While ink spray (bubbling) form head, ink at ink tank not flow to head.
Feb 02, 2010 | Canon PIXMA MP810 All-In-One InkJet...
How do I remove the print head from my Canon MP810 printer for a clean? :o)
I just replaced my MP810 printer head. Procedure: open printer - remove ink cartridges - Pick up arm located on right side of cartridge holder- remove printer head by picking up by the cartridge slots. Place new printer head in holder - replace printer cartridges - press arm down and your done....However, the error message stays on and reset procedure doesn't remove it. Canon tech support said their solution (because of distance from canon support) is to replace MP810 with comparable printer, which came to $299 with 15% discount and free shipping. My solution, I’m checking out other printers.
Jan 11, 2010 | Canon PIXMA MP810 All-In-One InkJet...
The printer suddenly refuses to print black but will print colour
try to set it in the default printer settings. it will go back to the original set up
Nov 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Wireless Printer Setup
For installing a wireless printer on Windows XP, wireless router is an essential device.
Follow the recommended steps mentioned on the installation CD of the router, and set-up a wireless network.
Since several computers or laptops will access the printer, it0 1is recommended to connect the wireless printer to the main computer through the USB port.
To begin the installation process on Windows XP, access the network setting in the Control Panel, and activate the file and printer sharing option in the LAN setting.
This will allow the operating system to recognize the availability of a wireless printer.
Now, click the Start button, go to Devices and Printers, select Add a Printer option.
Click the second option- Add a network, wireless or Bluetooth printer.
The computer will search for available printer and reflect it on the screen.
Click Finish; and the printer is ready to begin the printing process.
Feb 15, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Scanner driver problems for MP810
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Some Canon device may not be Vista compatible and cannot work on Vista.
Oct 30, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Canon Pixma MP810 Full Page Photo problem
Check your print settings and run an allignment check.
Sep 27, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Canon MP810
Try this Click on start click on run type services.msc a box will open up with listings Check each of the following to see if they are running LexBce Server- should be set to Automactic Print Spooler- Should be set to Automactic Remote Procedure Call(RPC)- Set to Automactic If any of these items are different- change them by double clicking on the line. A box will open up make changes then click apply. Shut down and restart your computer. Hope this helps you
Sep 15, 2007 | Canon PIXMA MP810 All-In-One InkJet...
294 people viewed this question
old marine
old marine
