Washing machine error E3 on my samsung big wash how can i solve it? and what as caused it? thanks bev
  • theparkhotel Jun 23, 2008
    dear Maanita,thanks for replying i made a mistake the error isnt E3 its 3E i did try what you told me i put another load of washing in but 2 mins after i started the wash it stopped then started to flash 3E can you help me again
    thanks Bev
  • 1,142 Answers
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Posted on Jun 23, 2008
2009 Samsung front load washer E3 error after water fills. Wont wash, only spins
go to the manufactures website and download the user guide its normally free to solve your problem eric
Dec 27, 2017 | Samsung Washing Machines
What does it mean E3
The E3 error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. Here is a link that will explain it better. Hope this helped Tim
Jan 02, 2017 | Washing Machines
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ... > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Samsung front load washer. What is causing E3 code?
My error code database says:
Error: E3,
Machine: Washing Machine,
Type: Samsung,
Fault: Too much water in machine. Check pressure chamber for blockage,check pressure switch and air hose for leaks, check solenoid for sticking or jammed valve.
Dec 26, 2015 | Washing Machines
Error e3
Thank you for your post, friend!
I understand that your Electrolux washer is displaying an "E3" error code while it is spinning. However, it appears "E3" is an invalid error code. It is possible that the error code is missing characters? I suggest resetting your washer. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, and your washer continues to display "E3" I would recommend contacting a professional to come and properly diagnose your appliance. -Matt
Aug 11, 2014 | Electrolux Washing Machines
After main washing, stops and can't spin. Gives error E3.
The "E3" error indicates that a Samsung washer's motor is not running properly. The cycle can usually be restarted by pressing the "Start/Pause" button. However, if the error code appears again, you should contact an authorized service technician.
Sep 25, 2013 | Washing Machines
Hi..Telmann tel6tl displays fault code E3..have you any ideas.. Thanks.
This code (E3) means an error code. That the dishwasher electronic control has detected a condition it needs to check. When you see a code, follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping if noted then .
  • Reprogram the Washing Machine.
  • If the code still displays, turn off the power to the Washing Machines at your breaker box and wait five minutes and clean all part (area) that are open to water carefully before turning it back on for operation.
Thanks for using fixya.
Jul 31, 2011 | Washing Machines
Error code e3
Display indication E3 is for error signal due to thermistor/short.For this you need to contact you are nearest washing machine service center.Or you should call Service Engineer.This is not a big problem it can be solved in few minutes.Thanks for your question.
Jun 19, 2011 | Washing Machines
Machine having same error E3 not spining, does water pressure influence
The error code e3 is related to weak motor or faulty motor brushes.The brushes gets worn out and causes this error code in most of the cases/.Check the motor brushes and replace/.But if the brushes looks fine then its the faulty /weak motor causing this problem.The cost for pair of brushes is $45.And the cost of new motor assembly is near to $230. -----------
You can get required parts from or from . ------------ Keep updated with any more queries.Thanks.
Oct 14, 2010 | Samsung Washing Machines
Washing Machines Logo
729 people viewed this question
Top Washing Machines Experts
