Question about Kyocera Mita FS 1010 Laser Printer
Kyocera FS1010 first page only half printed
I have a Kyocera FS1010 and every time I print the first page gets a huge top margin and the bottom of the page is missing. Subsequent pages are ok. Any clues?
  • 3 more comments
  • Anonymous Aug 22, 2008
    Yes me too but I *** not know how to do the suggestion that was provided
  • snlsrj Sep 19, 2008
    ya whenever i print on kycera mitra fs 1010 the first page gets a huge margin and later it works properly
  • Anonymous Jan 28, 2009
    I have this problem on several networked Kyocera FS-1010 printers it started about a year ago, has not effected the fs-1020 or fs-1030 printers
  • Anonymous Feb 09, 2009
    I had the same problem. I've reinstall windows and printer drivers and still same problem.
  • Anonymous Mar 16, 2009
    Obviously an issue, tried numerous drivers... to no avail !!
I found this solution. Worked a treat. I took the printer apart and applied felts to the solenoids (the felt normally used for the bottom of cup coasters).
See the Success post in this thread...
http://www.copytechnet.com/forums/kyocera/15980-kyocera-fs1010-delayed-printing-1st-page-2.html#post55451
This manual helped too...
http://www.freeprintermanuals.com/PM/Kyocera%20FS-1010%20Parts%20Manual.pdf
This is the post...
Success
A solution has been found. Thank you to Steveauh (Townsville)
Kyocera in their wisdom have used a foam insulator on the 3 solenoids that disintegrates over time regardless of use.
  1. Open the right side of the printer
  2. Disconnect all connections to engine board
  3. Remove engine board
  4. Remove plastic guard (white)
  5. remove all 3 solenoids
  6. Replace all pads on the solenoids that come up against stops
    Registration Solenoid has 2 pads (1 against the solenoid frame and the other on a stop arm, the others just the frame pad)
  7. Keep thickness to around .4 - .5mm Too thick on register arm will cause early printing.
  8. Reassemble
And that is it. The arms were being magnetically delayed due the metallic contact. It seems to be a regular problem in this chassis FS1000 to FS1030.
Posted on May 14, 2012
  • 2 more comments
  • Mark Beyerl Dec 19, 2012
    This works great and it fixed my printer.
  • Charles Mott-Gotobed
    Charles Mott-Gotobed Dec 18, 2013
    This worked for me as well after I raided an old coaster for the sponge! thanks, it had been bugging me for a year or more
  • Juan Jos? Pi Feb 21, 2014
    Hi. Could anybody add a picture of the pads and solenoid, please?. And it would be even better if the picture is from the FS1030D model. Regards
  • Bevan Shaw May 16, 2014
    2 years later and my trusty Kyocera is still going great.
  • 167 Answers
you need to do calibration printer in setup printer.
There it will set margins and paper size!
good luck
Posted on Jun 23, 2008
How do I change margin setrtings foe Lexmark P4350
If you are preparing to print a document that you have created in Microsoft Word, you may be concerned that all the text on the page will print exactly as you see it on your screen. This is not always the case. You can adjust your print margins to ensure that your text prints on each page exactly the way you would like it to appear.
Opening Your Document
Open your Microsoft Word document by double-clicking the Word icon on your desktop. If you do not see the icon on your desktop, then you can locate it where it is buried on your "Start" menu. Click "Start," followed by "All Programs." Then click "Microsoft Office," followed by "Microsoft Office Word." A new document will open on your screen. Click the "Office Button," followed by "Open." Scroll through the files listed, and double-click the one you would like to print. It will open on your screen.
Check Your Margins
By default, your page margins are set to 1-inch margins on the top, bottom, right and left of your page. You can check your margins or change them by clicking "Page Layout," followed by the "Margins" button.
Select New Margins
Select a different margin size, such as "Narrow," which indicate 1/2-inch margins, or "Wide," which indicate one-inch margins on the top and bottom and two-inch margins on the left and right. You also can select "Moderate," which indicate one-inch margins on the top and bottom and 3/4-inch margins on the left and right. Finally, you can select "Mirrored," which indicates one-inch margins for the top, bottom and outside. The inside margins are set at 1 1/4 inches.
Print Your Page
Print your page. Press "Control" plus the "P" button. The printer dialog menu will come up. Make sure that "All Pages in Range" is selected. Press "OK." If your printer cannot print your new margins, then a new menu will pop up telling you to adjust your margins.
I hope you find it very helpful. Best regards.
Aug 22, 2011 | Lexmark P4350 All-In-One InkJet Printer
Tip
Top margin, header page, the print is changed (lowered).
If you print and the top margin is altered (low), look at the figure below.
excuse my English.
on Oct 25, 2013 | Kyocera Mita FS-1030D Laser Printer
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
Printing Large Top Margin
check the header and top margin in your application. (word, Note pad, etc..)
default top margin for Microsoft word is 1".
also check the orientation of the printer output.
Nov 24, 2008 | Samsung CLP-500 Laser Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
HP PCS 750 cuts off bottom of 8 1/2 X 11 page when printing. Auto reduces page.I need 100%.
The PSC 750 cannot print a full borderless page, it requires a bottom margin of 0.46", a top margin of 0.08" and side margins of 0.25" when printing on 8.5x11 pages.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jul 04, 2008 | Office Equipment & Supplies
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
Kyocera Prescribe programming
hi, I think that You must set parameters for line space,or character space.Also set parameters for margines,L1L2,etc...
have You prescribe manuals? if not, You can download it from Kyocera web site,section downloads.
Nov 27, 2007 | Kyocera Mita FS-1030D Laser Printer
Kyocera Mita FS 1010 Laser Printer Logo
3,459 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
NewYork kyocera HP...
Henry Gertcher
Soulvisitor
Soulvisitor
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
