Posted on Jun 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer won't pick up paper & if it does it doesn't exit fully
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 17, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
137
Points
Finally gave up, HP is replacing pro 8500.
Anonymous
Level 3:
Genius:
  • Master 2,785 Answers
  • Posted on Jun 23, 2008
Anonymous
Master
Level 3:
Genius:
Answers
2785
Questions
Helped
860342
Points
7964
Plz send your printer for servicing
Anonymous
Level 2:
  • Expert 167 Answers
Anonymous
Expert
Level 2:
Answers
167
Questions
0
Helped
59803
Points
418
Problem is with paper roller! You need to clean it up. It's the best way with moisture cloth!
good luck
Canon ir2520 jamming in the exit tray
If your Canon IR2520 is jamming in the exit tray after initializing the machine, it could be caused by a few different issues:
  • Paper tray: Make sure that the paper tray is loaded correctly and that the paper is not jammed or loaded incorrectly. Also, check if the paper tray is not overfilled or if the paper is not wrinkled.
  • Pick-up roller: The pick-up roller is responsible for picking up paper from the tray and feed it to the printer. Check if it is dirty or worn out.
  • Exit guide: The exit guide is responsible for directing the paper out of the machine. Make sure that it is not blocked or bent, which could cause the paper to jam.
  • Fuser: The fuser unit could be malfunctioning. The fuser is responsible for heating and fusing the toner to the paper. If it is not working properly, it could cause paper jams.
  • Feed rollers: The feed rollers are responsible for feeding the paper through the printer. Check if they are dirty or worn out.
  • Paper jam sensor: The paper jam sensor may be malfunctioning. If the sensor is not working correctly, it may not detect a jam and the printer will continue to try to feed paper through.
  • It is recommended to check the copier's manual or consult with the manufacturer's technical support to troubleshoot the problem. They may provide more specific instructions for your specific model and can guide you through the process of finding and fixing the problem.
These are general suggestions and your specific case may require different actions.
Regenerate response
2answers
HP3390 picks up 3 pieces of paper sequentially for each page and jams just before first page exits
It appears to be known problem and the fix is to replace the pickup roller. The problem as you noticed is that it has dried out.
https://www.google.com/search?q=HP3390+picks+up+3+pieces+of+paper
Brother HL-5250DN paper light fashing
disconnect all usb cable from computer .power off again power on
press & hold down go button press t times if print , reset printer drive in your computer or not print test page replace drum unit .
Printer read out states "lower exit tray" /
More paper was loaded so that the "Pick up" mechanism could
still work. It would seem that that the spring loaded paper pick-up mechanism was therfore the real problem - not the exit tray !
1helpful
Many paper jams at fuser exit. We open the side door remove the paper inspect for anything that might be hung up inside and find nothing. The printer will print 5-6 pages more and jam again.
I would try cleaning to paper pick up rollers incase its not picking the paper all the time i would also check the exit sensor to see if its sticking hope this helps.
5helpful
3answers
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
k24674
ADMIN Andrew
ADMIN Andrew
