Computers & Internet Logo
Posted on Nov 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Windows will not start general system failure
Brian Sullivan
Level 3:
  • Medion Master 27,725 Answers
  • Posted on Nov 25, 2010
Brian Sullivan
Medion Master
Level 3:
Answers
27725
Questions
Helped
5664225
Points
79191
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
General system board failure The LEDs near Caps
Your laptop has an external vga card
Thats usually the first suspect
Try reheating the one you have and if that works, even for a little while,look for a replacement
Malfunction indicator lamp on
1. The failure lamp general descriptions
Fault indicator light on the dashboard; General color is red (refer to the vehicle manual) on electricity self-inspection, failure indicator Chang Liang out after 2 seconds; Efi system failure after the light; General failure, failure indicator light Chang Liang; Serious failure, failure indicator light flashing; Failure disappears, failure indicator light put out automatically.auto diagnostic tool
PS3 won't turn on. Green light then switches back to red. Cannot eject disc
This is a system failure. The only thing a general user can try is to unplug the system, and replug all the cords in again (including video) this is to make sure it is not a general cable failure. If this does not work then you need to have the ps3 serviced for the yellow light of death (yeah they say yellow even though its red)
problems can be:
cpu
gpu
hard drive
optical (bluray) drive
general failure
component failure
and more.
I TURN MY KIDS PC ON AND IT STARTS UP BUT THEN IT GETS TO WINDOWS AND IT LOOKS LIKE IT IS ABOUT TO COME COME UP BUT GOS TO THE BLUE SCREEN FOR 1 SECOUND AND STARTS BACK UP AGAIN OVER AND OVER.
A blue screen or Blue Screen Of Death, BSOD, is generally caused by a corrupt driver or a bad software installation.
First, you need to determine the STOP code that is on that screen.
  • Start in safe mode, press F8 repeatably as the computer starts up,
  • check Disable automatic restart on system failure (This prevents Windows from automatically restarting if an error causes Windows to fail.)
OK, now the BSOD will stay there so you can determine what caused your problem. Report back the stop code and any information about a driver that caused the problem so we can be of further help.
PXE-E61 media failure when i start up my computer
The PXE-E61 failure is a failure to boot to the network card, this generally indicates a problem with the hard disk drive.
  1. Boot to the BIOS and reset the defaults
  2. Reseat the hard drive
  3. Boot to Windows CD and run CHKDSK /R on HDD
If the system will not boot to the HDD, but it is seen in BIOS, then the HDD may have an OS issue, if not detected in BIOS HDD likely has failed.
Windows XP with SONY RW-AW-G170A DVD Rewriter.Unable to format UDF on DVD disc even after disabling-in built CD burning engine.Formatting starts fine but after afew minutes alert message appears:...
THIS PROBLEM SEEMS TO NOT UR DRIVE BUT
1. WITH UR SOFTWARE OR
2. THE DISK U R USING
MAX TIMES THE DISK CAN NOT FORMAT SO 1st TRY TO CHANGE THE DISK
I THINK THIS WORKS
PLEASE VOTE FOR ME
it very well could be the disc themselves, some computers like i certain kind better, my husbands only likes sony dics, wont burn on anything else, try that it might solve the problem...shia
Computer giving error: "harddrive error press ctrt alt sup to restart" on start up please help.
Generally, such an error indicates the hard drive has had a severe failure and needs to be replaced.
If a portable, you can try reseating the drive. If a desktop, you can reseat the cables.
Check in the system BIOS, see if the hard drive is identified by size/model, if it is, then you can try running diagnostics on the drive to see if you can get a failure code.
if diagnostics pass, you can try booting to your Windows CD, and run tools like CHKDSK and BOOTCFG /rebuild to fix the file system.
But you are getting a BIOS level error from what you describe and that usually means replacing the hard drive.
Top Medion Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
SmartAviator
SmartAviator
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
