Question about Brother MFC 7420 All-In-One Laser Printer
Manual feed how to solve problem with manual feed, insert paper message? Dusko
  • 7 more comments
  • Anonymous Jul 03, 2008
    same problem
  • bettyrita Jul 08, 2008
    suddenly it says manual feed insert paper and won't print anything
  • Anonymous Sep 08, 2008
    Maual feed insert paper can not find solution
  • Forsey Finba Sep 11, 2008
    Same problem. Nothing in user manaul on how to fix......help someone please
  • becca388 Sep 12, 2008
    its saying manual feed insert paper and its not printing
  • Anonymous Oct 10, 2008
    same prob and switching on and off doesn't do anything. Selecting 'File/Page setup/Paper - Paper Source' tab & selecting 'Default tray' on all options doesn't help. Under 'File/Print/Properties (or Preferences if you are printing an internet page)/Basic/Paper Source/First Page - Auto Select or Tray1' doesn't work either!!! Pls help.
  • nuttkaz Nov 04, 2008
    oops i meant that as a problem not as a solution!! How do you change manual feed to automatic feed?
  • Anonymous Mar 07, 2009
    When I try to print a document, it defaults to manual feed.
  • scargo1013 Apr 02, 2009
    The LCD shows "Manual feed, insert paper". How do I change it??
I tried the 30 seconds, it didn't work but finally found it. It's apparently not in the brother configuration, but in the program configuration.
Say you are using MS Word, you need to goto Page Setup. Middle of the page, you will see "Paper Source" TATA! Tray 1 is there.
Auto Select is kinda dumb, might still goto Manual Feed so there u go :)
Cheers
Posted on Apr 26, 2009
Apparently this arises out of a software progarm you msut be suing. Sorry but I'm so technologically illerate that I am unsure what the Brother Helpdesk was really meanning. Anyway after lots of dieffernt attempts at various things, I turned it off for 30 seconds and presto shes fixed. Ridiculous I know but it worked for me
Posted on Sep 12, 2008
This worked for me:
Turn off printer.
Turn off computer.
Wait 30 seconds.
Turn on printer.
Turn on computer.
Posted on Apr 04, 2009
That did not work for me.....u got anything else up your sleeve?
Posted on Nov 04, 2008
Brother manual feed insert paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC 7360N - Multifunction fax /...
Every time when printing there is a message MANUAL FEED, load paper and click continue
Please check your printer driver to see if the default tray is tray 2 or other than the manual feed tray and take the paper out of the manual tray.
May 03, 2011 | HP LaserJet 3200 All-In-One Printer
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
WHY DOES THE MESSAGE MANUAL FEED INSERT PAPER KEEP COMING UP ON MY MFC7420
if you are trying to print something from your PC and machine has NO paper in tray she will ask you for manual feed. Look in your printer driver properties to see what PAPER SOURCE is chosen.
pifonski
Feb 20, 2011 | Brother MFC 7420 All-In-One Laser Printer
I have a MFC 7440N and it keeps giving the message Manual Feed Insert Paper. What do have to do to have paper from the tray? Please help
You need to open the front long small cover and feed the paper from that manual feeder.
after that, you should be good.
Feb 15, 2011 | Brother MFC-7340 All-In-One Laser Printer
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
"manual feed insert paper". the machine is stuck with this message brother mfc 7840N
This means at some point the machine was told to copy or print from the manual feed. So you need to put some paper in the manual feed so it will print out and clear the message. You can try turning off the power, sometimes this will clear the message as well.
Aug 25, 2010 | Office Equipment & Supplies
Paper feeds fine from the manual tray but the main tray (the bottom) I continuously get a paper jam. It begins to feed then jams. Anything I can do to fix this?
Dear,
No problem.I can solve your problem.There are printer has two paper feed system 1) manual feed2) on cassate.When you get a paper jam in cassate you clean paper clauth or cassate feed roller clean.Some times is missfed because it can not creat frashor in correct.Clean it then solve you problem.Or some of paper bit here.
Dec 09, 2009 | HP LaserJet 1320n Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Epson r2400 won't feed paper
I had the same problem, then found these instructions for cleaning the feed roller: http://www.museofineart.com/files/RollerCleaningProcedureRev2.pdf I used the paper towel method and it's working fine now with no issues.
Oct 20, 2008 | Epson Stylus Photo R2400 InkJet Printer
Brother MFC 7420 All-In-One Laser Printer Logo
666 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
