Question about Intel Desktop Board D915PGN - Motherboard - ATX - i915P - LGA775 Socket - UDMA100, SATA - HD Audio
Hard desk a blue message appears when the windows started tels me that the hard desk has a proplem may be form virus, new hardware, or new hardware controler. i tryed to install a new windows but this message interrupt it. please help me
    Sergeant:
  • 458 Answers
Here are some solutions that I have for you.
HARD DRIVE PROBLEM
This sounds like a bad hard drive. What make of hard drive is in it?
Figure out what brand hard drive it is first. Then go to the website of the manufacturer.
While you are on the site look for software for hard drive repair. It could be listed in many ways. Download the windows version if you have another computer to test this in. If you do not have another computer to test this in you will have to use the Dos version. The instructions will come with the software.
Then you will go through these steps.
Do you have another computer that you can use to check the hard drive? If you have another computer or access to another computer you can download a hard drive utility that can diagnose and possible repair the hard drive. Is it a SATA hard drive? If it is a SATA hard drive you can plug it directly into another computer that has a SATA cable. If it is not SATA you will need to buy a converter so that you can hook it up to the other computer. This will be an external slim hard drive enclosure. A desktop hard drive can be put in another desktop and used as a slave drive. Just make sure that you look at the back of the Hard Drive and make put the jumper on the slave pins. Then you can run the test through the other computer to test the Hard Drive. The test will let you know if the Hard Drive is bad or not. If you can see your files on the drive you might want to back them up before you start the test. If it comes back as good go to the next step.
FIX BOOT
You can boot it up with the recovery CD and run through it as if you were doing a setup and then when the second repair comes up..... hit repair. This should repair any problem with the operating system. If you want to try the simple way... use the first repair that comes up. When the screen comes up with a blinking curser hit the number 1 then Enter........ When it ask you for a password hit enter. There should not be a password unless someone has put one in it. If there is a password it should be your master password.
Then type fixmbr and hit enter. This will fix your master boot record. If that does not work use the second repair. Sounds complicated but it is not.
Posted on Jun 23, 2008
Windows xp sp3 stop error message 7e usb
Why not just pull it out instead of clicking on safely remove hardware? Try it and see if it works. Sounds like your usb drive is not windows 7 compatible. Or windows 7 has some driver issue which is not uncommon.
Jun 04, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
Tip
Things You Must Know To Avoid PC Crash Part 2
4 Hard disk drives
After a few weeks, the information on a hard disk drive starts to become piecemeal or fragmented. It is a good idea to defragment the hard disk every week or so, to prevent the disk from causing a screen freeze. Go to
* Start-Programs-Accessories-System Tools-Disk Defragmenter
This will start the procedure. You will be unable to write data to the hard drive (to save it) while the disk is defragmenting, so it is a good idea to schedule the procedure for a period of inactivity using the Task Scheduler.
The Task Scheduler should be one of the small icons on the bottom right of the Windows opening page (the desktop).
Some lockups and screen freezes caused by hard disk problems can be solved by reducing the read-ahead optimisation. This can be adjusted by going to
* Start-Settings-Control Panel-System Icon-Performance-File System-Hard Disk.
Hard disks will slow down and crash if they are too full. Do some housekeeping on your hard drive every few months and free some space on it. Open the Windows folder on the C drive and find the Temporary Internet Files folder. Deleting the contents (not the folder) can free a lot of space.
Empty the Recycle Bin every week to free more space. Hard disk drives should be scanned every week for errors or bad sectors. Go to
* Start-Programs-Accessories-System Tools-ScanDisk
Otherwise assign the Task Scheduler to perform this operation at night when the computer is not in use.
5 Fatal OE exceptions and VXD errors
Fatal OE exception errors and VXD errors are often caused by video card problems.
These can often be resolved easily by reducing the resolution of the video display. Go to
* Start-Settings-Control Panel-Display-Settings
Here you should slide the screen area bar to the left. Take a look at the colour settings on the left of that window. For most desktops, high colour 16-bit depth is adequate.
If the screen freezes or you experience system lockups it might be due to the video card. Make sure it does not have a hardware conflict. Go to
* Start-Settings-Control Panel-System-Device Manager
Here, select the + beside Display Adapter. A line of text describing your video card should appear. Select it (make it blue) and press properties. Then select Resources and select each line in the window. Look for a message that says No Conflicts.
If you have video card hardware conflict, you will see it here. Be careful at this point and make a note of everything you do in case you make things worse.
The way to resolve a hardware conflict is to uncheck the Use Automatic Settings box and hit the Change Settings button. You are searching for a setting that will display a No Conflicts message.
Another useful way to resolve video problems is to go to
* Start-Settings-Control Panel-System-Performance-Graphics
Here you should move the Hardware Acceleration slider to the left. As ever, the most common cause of problems relating to graphics cards is old or faulty drivers (a driver is a small piece of software used by a computer to communicate with a device).
Look up your video card's manufacturer on the internet and search for the most recent drivers for it.
6 Viruses
Often the first sign of a virus infection is instability. Some viruses erase the boot sector of a hard drive, making it impossible to start. This is why it is a good idea to create a Windows start-up disk. Go to
* Start-Settings-Control Panel-Add/Remove Programs
Here, look for the Start Up Disk tab. Virus protection requires constant vigilance.
A virus scanner requires a list of virus signatures in order to be able to identify viruses. These signatures are stored in a DAT file. DAT files should be updated weekly from the website of your antivirus software manufacturer.
An excellent antivirus programme is McAfee VirusScan by Network Associates ( www.nai.com). Another is Norton AntiVirus 2000, made by Symantec ( www.symantec.com).
on Feb 02, 2010 | Computers & Internet
Tip
Hi! Plz help me I have satellite L305-S5908 I had deleted my windows vista 64...
NOTE: This Tip can be Hard, I recommend Advanced Users Only.
The first issue we encounter is that computers with pre-installed operating systems take up the entire drive. Luckily Microsoft included the Shrink volume feature in Vista, so we can easily shrink the Vista partition down to make room for XP.
Open the Computer Management panel, which you can find under Administrative tools or by right-clicking the Computer item in the start menu and choosing Manage. Find the Disk Management item in the list and select that.
Now we'll shrink our volume down by right-clicking on the main hard drive and choosing Shrink Volume.
Now you can choose the size that you want to shrink, which really means you are choosing the size that you want your XP partition to be. Whatever you do, don't just use the default. I chose roughly 10gb by entering 10000 into the amount.
This step might be confusing, because we need to change the cd-rom drive that's invariably taking up D: at the moment, because we want to use D: for the Windows XP partition, but it's already taken by the cd-rom drive. If you skip this step than XP will install onto the E: drive, which isn't the end of the world, but it's not quite as tidy.
Right-click on the cd-rom drive in the list and choose Change Drive Letter and Paths from the menu.
Now we'll change the CD drive to use E: by selecting that in the drop-down.
Now we can create a new partition for XP to live on and make sure that the drive letter is set the way we want. If you do not create a partition now the XP install will do so automatically, but it's easier and cleaner to do it this way.
Right-click on the Unallocated free space area and then select New Simple Volume from the menu.
Follow through the wizard and select whatever options you'd like, making sure to use D: as the drive letter.
Now you will need to close out of disk management and reboot your computer. This is because we can't do the next step until we reboot. (you can try, but it won't work)
So we've come back from rebooting… open up Computer from the start menu and then right-click on the D: drive and select properties. Give your partition a meaningful name like "XP". It would be wise to name the C: drive to "Vista" at this point as well.
Now you'll want to pop your XP cd into the drive and boot off it. You may have to configure your BIOS to enable booting off the CD drive, or if your computer says something like "Hit Esc for boot menu" you might want to use that.
Once you come to the screen where you can choose the partition to install on, then choose either the unpartitioned space or the new partition you created. Whatever you do, don't try and install onto your Vista partition! See how much cleaner it is now that we've labeled each partition distinctly?
We'll assume XP is completely installed at this point, and you will have lost your ability to boot into Windows Vista, so we'll need to use the VistaBootPro utility to restore the Vista boot loader.
Download and install VistaBootPro from vistabootpro.org
During the install you'll be forced to install the .NET 2.0 framework. Open up VistaBootPRO and then click on the System Bootloader tab. Check the "Windows Vista Bootloader" and then "All Drives" radio buttons, and then click on the Install Bootloader button.
At this point, the Windows Vista bootloader is installed and you'll only be able to boot into Vista, but we'll fix that. Instead of manually doing the work, we'll just click the Diagnostics menu item and then choose Run Diagnostics from the menu.
This will scan your computer and then automatically fill in the XP version.. click on the "Manage OS Entries" tab and then click in the textbox for Rename OS Entry, and name it something useful like "Windows XP" or "The Windows That Works"
Click the Apply Updates button and then reboot your computer… you should see your shiny new boot manager with both operating systems in the list!
If you get an error saying "unable to find ntldr" when trying to boot XP, you'll need to do the following:
  • Find the hidden files ntldr and ntdetect.com in the root of your Vista drive and copy them to the root of your XP drive.
  • If you can't find the files there, you can find them in the \i386\ folder on your XP install cd
You can share information between the drives, but I wouldn't recommend messing with the other operating system's partition too much… it might screw up your files. What I do recommend is that you store most of your files on a third drive shared between the operating systems… you could call that partition "Data".
This works if you have the operation system "Windows Vista."
on Mar 28, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
When I am starting my Lenovo G550,Model Name-20023 it restart with blue scrren. I am trying to start it in safe mode but same problems appears. Then I am trying to format the system with windows XP-2 but...
If you get a blue screen then you have a piece of hardware loose inside your lappy or could be a loose cable on the hard drive or cd/dvd rom, since lappy's are very hard to take apart it's best to take it to a shop to get fixed sorry.
Jul 08, 2011 | Computers & Internet
Blue screen
BSOD? Okay, this is what you do, bash your head on your desk first because you've probably installed or bought Windows Vista. Then, go buy Windows 7 and install it.
Jun 20, 2011 | Computers & Internet
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
Mother bord(asus)
Hello suresh_7chan,
This can be either a software problem or a hardware proble.
Most likely hardware problem is the primary hdd. (Hard disk drive).
To check the hardware end of things. Re-check all data & power connections within the system, paying close attention to your primary hard disk drive. Most blue screens leave a message. If you can write down the message from a blue screen it can be helpful. (Some blue screens go by very fast & it may be too hard to write down the message generated by windows). Another suggestion. If your hdd is large enough, 80GB or more. You can load your windows CD into your CD-Rom drive & boot to the windows CD. In the few screens that windows will display during setup. You'll have the option to create a second partition within the free space of your hdd. Create a new partition & allow windows to do a quick format.
Once completed, install windows into that new partition. Up date windows to SP2, at least. If windows runs correctly without blue screens or sudden restarts, than your old windows is either infected with a virus/worm or just messed up. install antivirus software & run a full system scan. You can use windows disk manager software to change the old C:\ to something like G:\. To run windows disk manager software, click the start button & open run. Type, diskmgmt.msc into the run window & click ok.
Again, if your new install of windows functions correctly & no virus has been found you can copy your old data to your new install of windows. (This is so you do not loose your data).
Jan 21, 2009 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
When I turn on my dell c600 laptop, it stays on for about 1 minute then a blue screen appears with a bios error message. How do i fix this?
From the minimal description you provided, it sounds like 1 of two things. Either OS problem/virus/spyware or bad hardware. Try to write down the message generated when the BSOD (Blue Screen of Death) appears and google it.
To scan for bad hardware (sounds like it might be a bad hard drive), use the tool Hiren's Boot Disk 9.4. Replace the bad part and then update the system/reinstall windows (if it's the hard drive)
Good luck
Jan 01, 2009 | Dell Latitude D600 Notebook
My computer wont start up
First try pressing F2 at start up to see if you can get to setup. Also pressing F12 may get you a boot menu. If cd is already set as first boot you may get a chance to boot from a Windows cd. The idea here is to get to a minimal Windows configuration like setup or safe mode (F8) to see if this is a hardware or operating system fault. Two common issues with eMachines are power supply problems where repetitive reboots can actually fry the motherboard or if the PC has a few years use the CMOS battery. Steve Medley
Oct 30, 2008 | E-Machines eMachines Desktop PC
Isn't being read anymore
Please repair the master boot record(mbr) might be damage cause of viruses. If the harddrive detected in the CMOS there is no possible that can able to format the harddrive using windows utility such as XP Bootable CD or 98SE.
Hope this will be helpful to you.
Oct 25, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Intel Desktop Board D915PGN - Motherboard - ATX - i915P - LGA775 Socket - UDMA100, SATA - HD Audio Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
