Question about Toshiba TDP-T9U Multimedia Projector
Toshiba tdp-t9u projector
My Toshiba TDP T9U will turn on for less than 5 minutes, then the screen will flicker and get discolored. After a couple of minutes of that, it will start to make a noise and then turn off. Please help me and tell me what the problem is and what I need to do about it!
    Problem Solver:
  • 6 Answers
You have a bad or loose cap on the main board very difficult to repair as the is a sufface mount board if you don't know how to repair this type of
board don't try you will make it worse!!
Posted on Sep 03, 2009
  • 22 Answers
It is likely your bulb is going out, or your fan is broken & it is oveheating.
Posted on Jan 09, 2009
Toshiba TDP-T9. the light won't change from yellow to green. we tried restarting the computer and the projector, but nothing seems to work.
Well first check the colour scheme of your monitor and of the projector.
If this doesn't work check the working hours of the lamp. Try cleaning the filters and if this doesn't solve your problem the best thing to do is to change the lamp of the device.
If you need further assistance please leave a comment. Cheers
Aug 25, 2010 | Toshiba TDP-T9U Multimedia Projector
42HP95 TV screen flickers off/on
Can be either one of three things 1) logic board, power supply, or unfortunately most likely is your panel. But if I were you I'd get a hold of Toshiba warranty center to diagnose because then they could check voltages with toshiba tech support.
Aug 23, 2009 | Toshiba 42HP95 Television
Toshiba Projector TDP-S20U. Horizontal Bar.
it can be also due to faulty ballast or the colour wheel due to which the horizontal bar is showing up.also if the buklb is giving less light /glow that means its weak should be the cause of this problem.as the voltage of the bulb should be checked  how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 06, 2009 | Toshiba TDP-S20U Multimedia Projector
Trouble with output to the projector
Hi there
Check the following on your laptop.
Right click on your desktop , go to properties and settings - check if your resolution of the PC is the same as that of your Projector. i.e. 800x600 or 1024x768
Also check that your secondary monitor is attached / activated.
If the signal stil won't pick up - hold down the Fn ( function button) left of your spacebar and press in your F-row of buttons the one with 2 screens on it. ( differs from brand and model )
Hope this helps you and good luck with your class tomorrow !
Mar 31, 2008 | Toshiba TDP-T9U Multimedia Projector
Toshiba tdp-t9 (everyday t.v.) with no hdtv hookups
Yes you can hook up your Projector to ur cable box thru componet to RGB conversion Cable. that will work. i am also there on v_dhiman@hotmail.com
Apr 16, 2007 | Toshiba TDP-T9U Multimedia Projector
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
Toshiba TDP-T9U Multimedia Projector Logo
194 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
