Question about byD sign d:5032 50 in. HD-Ready Plasma Television
Screen wont come on
The tv made a pop like glass breaking i took the back off the fuse was popped but changed the fuse popped again i unplugged the board on the right side of the tv the screen came on with little White lines i try ed to call the 1800 number for the tv but its no good how would i go about getting this fixed under warranty
  • 1 more comment
  • keith_g320 Jun 23, 2008
    the power supply fuse don't pop there are 3 fuse the main one and one that goes to each board for the screen the one for the right board keeps popping its under warranty but the numbers i have for byd:sign don't work
  • keith_g320 Jun 24, 2008
    need help where do i bring this tv to get fixed cant get a good number for them its a byd:sign
  • luis719 Oct 26, 2008
    I have the same problem. Does anyone have a good phone number to call the manufacturer? THANKS
    Novelist:
    Champion:
  • 236 Answers
Well keith if it is under warranty it is best not to do anything with it but get it brought back to the seller. doing something with it could nullify the warranty.
as to the unit, you have a problem with the power suopply that's why the fuse keeps on popping. it needs more troubleshooting. but as i said have it checked by the manufacturer first since under warranty.
Posted on Jun 23, 2008
After a power outage my Panasonic smart tv came on for 2 seconds but after that it turned off and it wont come on after 24hrs
The power outage probably popped an inside fuse or damaged some electronic components. If you are capable, unplug the tv and place it face down on a soft towel. Unscrew all the screws on the rear that hold the two halves together. Lift the back panel slowly making sure all is free. Look for the fuses and check if they are blown. If they are, replace them with the same rated fuses. This is the cheapest fix. If the fuses pop again after this, then something beyond the fuse was damaged. You will need a repair shop to troubleshoot it. Once fixed, plug the tv into a surge protector for future use. Hope this helps.
Apr 09, 2016 | Panasonic Televison & Video
Power flickered during thunderstorm, TV wont come back on. heard little pop from tv when lights flickered.
Unplug it and take the back off. Look too see if the fuse right next to the power cord is black. Replace it. If it pops again, you have damaged the board and need a repair guy. Look for any burnt parts before replacing the fuse.
Jun 16, 2011 | Panasonic CT-32D12D 32" TV
I have a 56" vivitek Dlp TV rp56hd21-A. I replaced the bulb about 3 monts ago, since then it has been making a humming noise. Today I turned it on and it made a loud pop, lost all power. Now, it has no...
hello the pop could have been the glass fuse inside if you take back off you should be able to see the glass fuse in the power supply if you replace the fuse and blows again the you have dead short
shaun
Nov 07, 2009 | Televison & Video
72 inch rear projection tv took a power surge last
if ure handy pop the back off and there should be a main power board and a fuse on it, make sure you use the same fuse if it is blown do not stick another type or size in it, put it back together and turn it on if it blows again it will be somthing else if not it should work
Sep 10, 2009 | Televison & Video
Tv plays sound but no picture or any signs of backlight
This sound is a capcitor pop and this could be in the power supply unit itself. The glass could be a fuse that took the brunt from the capcitor pop.
1. Unplug the unit and do not plug it in.
2. if its under warrenty take it in please!
3. if its not under warrenty and you know eletronics verify what cap popped and replace that and the fuse.
4. if you do not know about eletronics this work would cost you around $150 for the wrok done.
Good luck I hope this information helps you!!
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
Dark band at top of screen...now whole screen
Pop sound is probably the Lamp or maybe the color wheel. When you unplug and try it on do you hear a whirling or winning sound ? Is it followed by a slight ticking sound ? If you get the whirling and a ticking sound it's probably a bad lamp. If you don't hear the whirling sound you may have a bad color wheel. The parts are both made of glass. The pop you heard was one of them breaking. If you can't tell, order a lamp you will need to change it eventually anyway.
Apr 16, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
Mitsubishi VS-45609 TV While having problem with convergence on my TV, I tried to adjust the settings. As I was messing with the buttons the TV froze and no buttons would work. I unplugged it to turn it...
I am at the same state your in the tv from back side of it inside holds 3 little glass fuses did you check those? for fuse pop i did mines still good
but still wont power back on just a quick blink from front when the power is plugged back in
Feb 20, 2009 | Mitsubishi VS-45609 TV
TV wont turn on at all.
It might be as simple as the fuse on the doubler board.
If you are capable of TV repairs, inside the TV, where the power cable connects to the board, there should be a small glass fuse. Check that to make sure it is not open, if it is, try replacing it with the same amp and voltage, if it pops again, then it is something more serious like a short some where.
Nov 24, 2008 | Akai PT4799HD Rear Projection Television
byD sign d:5032 50 in. HD-Ready Plasma Television Logo
155 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
