Question about Electrolux Ovens
Electrolux Oven Hi I have purchased a 4 year old house that has the appliances included. However I cannot operate my Electrolux oven? I am not sure what is wrong with it and the previous buyers have not included the operating manual. Can you tell me how to turn it on? I have tried all the combinations and the lights on the oven come on but it does not heat up? Thanks
  • emearoleary Jun 23, 2008
    Thank you for your comment! Can you tell me how I would fix this?
    President:
  • 1,462 Answers
If the fan inside the oven cavity is operating as well as the light, then the problem is probably the circular element is open circuit.
get back to me if you want - fairly easy to fit and not too expensive
Posted on Jun 23, 2008
  • douglas smith Jun 23, 2008
    you will need to get oven out and remove back panel. check with a multi-meter for continuity across the element - the terminals are exposed when you remove back. remove all wires from element when you check continuity but make a note of where they go.
    if you don't have access to a meter there is another way if you are carefull
    again remove all wires from element and connect direct from mains supply to the element and see if it heats up
How do I remove the clock/timer assembly that is integrated into the glass fascia panel of an Electrolux oven EOB63100K? The new part I have purchased is complete with its own small fascia panel
Open the oven door and remove the two screws. Pull out the oven and disconnect it from the power source.
To replace the timer you should to remove the two upper cabinets of housing of the oven.
Dado
Feb 18, 2015 | Electrolux Ovens
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Jan 10, 2015 | Electrolux Ovens
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
Whirlpool oven not heating up, though grill, fan and light still
Hi.
If fan in oven is working o/k, then the prob is most likely the oven element is faulty, and needs to be replaced.
Please rate my solution.
Thanks.
Aug 20, 2009 | Ovens
Oven light
Hi there it's possible that you are using an incorrect bulb in your oven....ensure on purchasing relacements that these are OVEN Bulbs (these are special bulb to operate at high temperature) ensure that the bulbs are screwed correctly and firmly into the holders and the glass cap is correctly fitted and secure.....
regards Sir Galahad
Mar 10, 2009 | DCS Large Appliances Built-In Ovens...
Glass
glass is glass. wouldn't say its normal but not an unheard of complaint, YOu purchased an ICON, id call the manufacture, wouldnt be suprised if htey took care of that for you! thats their pride and joy!!!!!
Feb 27, 2008 | Electrolux ICON 30 in. Double Wall Oven
Electrolux EOB5600 electrical fault?
goto home depot,lowes and get some ceramic wire nuts and heat tape and electrical tape.cut the wires back on both sides of the terminal block.bypass the t-block and connect the wires with the wire nuts wrap the heat tape then electrical tape on each one.if you have access to a amp meter take readings to make sure the amp draw isnt too high.i would think the wires just burned up from either a loose connection or the heat of the oven.this should solve your problem.
Jan 06, 2008 | Electrolux EOB5600 Ultrafan Electric...
Ovens Logo
122 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
