Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips HDTV I have my ps3 connected to my tv with component cables and had it running perfectly, but now when i go in AV-4 witch is HDTV it just shows a squiggly picture. Any Solutions ?
  • 138 Answers
You will need to make sure the resolution pn the PS3 is set the tv picks up whatever signal is sent toit no adjustment has to be made through the set.
Posted on Aug 19, 2008
Tv say "no signal" when
Hmm your PS3 should not be using AV out because your game signal is going into your TV, Try using HDMI 1,2, or 3 also there should be av in components in your TV as well.
Jul 02, 2011 | Philips 32PFL3504D 32 in. LCD TV
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    50' philips plasma tv has sound but picture is distorted
    I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
    Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
    I have a new ps3 slimline,cant get a connection t my samsung HDTV
    What you need to do is use a different tv or scart/av cable first, go to settings and reduce the resolution its because the tv cannot handle such a high res, if this dosent work, please post back, Regards
    Dec 25, 2009 | Sony Playstation 3 (PS3) Console
    I have ps3 but only a normal tv not hd how do i connect
    first if you do not have one you will need an HDMI cable, depending where you get it, it can cost you anywhere from $15-$165 it doesnt matter which one you get they all work, now if you dont got one an hdtv is next with a hdmi hookup,
    easy way, have your ps3 on, then plig hdmi to back of ps3, then go to the sisplay settings and change it from AV component to HDMI and there you go.
    harder way, ps3 off, hdmi in, av component not plugged in, reset ps3 till you get the picture on your HDTV
    Oct 14, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 hdmi format not supported
    Tries something else with a HMDI with the Phillip Tv.Like DVD player With HDMI see if it work with the TV.Narrow it down might have to use all the HMDIs inputs use.See if it all works.
    Might just have one or two HMDIs shorted out put.
    Sep 04, 2009 | Televison & Video
    HD WONT WORK ON MY PS3!!!
    Hi
    Try This links and follow the instructions! CLICK HERE
    Thanks!!
    Nov 12, 2008 | Philips 27PT8302 27" TV
    Help
    how are you connected to your tv? if your are connected in HD mode (hdmi cable) you will only get a 16:9 picture... SD mode (AV cable, S VIDEO cable, Component AV cable or SCART) will transmit a picture of 16:9 or 4:3 (4:3 being the old 'square screen' mode)
    Oct 01, 2008 | Sony Playstation 3 (PS3) Console
    Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
    Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
    Dec 30, 2007 | Yamaha HTR-6130 Receiver
    Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
    69 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
