Question about Panasonic CW-1006FU Air Conditioner
Replacement My airconditioner has started to leak water into the room, and is becoming noisier. Does any one know what would be the cureent model replacement for it? Also, the manual says if it is leaking into the room to tilt it back, but it is wedged in tightly, and has also never done this before, so I suspect this may not be the problem. Again, any suggestions? I have the same problem with my CW-1006FU. Last time I called in a repair person, this time I'm about ready to try and replace the whole thing. I tried to find the drain tube, but I'm new to looking inside my AC, and I don't know exactly where to find the darned thing. If I have removed the front of the AC, where exactly is the tube? (Sorry, I tried to find a breakdown of the Panasonic AC's interior, but I couldn't find anything on-line). Also, does anyone know of any AC that could replace the Panasonic CW-1006FU? (Just in case this doesn't work?)
    Master:
  • 638 Answers
Remove the front panel, & look for the drain tube that runs from the drip pan under the cold coil. It is likely blocked & may be cleared with a piece of coathanger wire. Be gentle.
or
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
or
Here is what a typical owner's manual will advise:
1) Unplug the unit and remove it from the window (beware, these are heavy!). Put it where you can work on it outdoors.
2) Remove the grille and filter and unscrew the metal case. Be careful not to damage the coil's fins.
3) Wash out the filter or replace it with a new, inexpensive filter--cut-to-size foam filter fabric is available at most appliance stores.
4) Using a vacuum with a soft brush attachment, clean the inside coil's fins.
5) Then, from the fan side, spray water back through the fins (protect the wiring and motor with plastic).
6) Clean it up with a rag, making sure all drains that allow condensed water to drip away from the unit are open. Allow it to dry thoroughly.
7) While you have the unit apart, lubricate the motor according to your owner's manual instructions.
8) Then reassemble and reinstall the unit.
If that doesn?t do it, clean the evaporator and condenser coils.
or
this is a link to help you
http://www.howtorepairairconditioners.com/acrepair/index.html?gclid=CIDtroaCipQCFRRnegodalYnWA
rate it as fixya if this helps you anyway.thanks. bye.
Posted on Jun 23, 2008
  • Panasonic Master
  • 13,433 Answers
I've not found a repair / service manual for you to guide you.
here are the operateing instructions, may be helpful
http://service.us.panasonic.com/OPERMANPDF/CW1005FU.PDF
you can find replacement parts for your product from this page
http://www.pasc.panasonic.com/Epartr/PartsList.asp
Well, I've found everything else but the instructions for how to repair it. Doesn't seem to be publicly shared, maybe you can contact panasonic for the manual.
    Brigadier General:
  • 3,614 Answers
Do you want it to be in repair, or you want it to replace...?
We have a fujitsuAST30RGA-W airconditioner, it is leaking into the room. can a new indoor unit be purchased, does anyone know? the unit works well, apart from dribbling all over the place.
it has to be set on a tilt in order to drain out the rear if it's condensating really bad it may need a freon charge you should take it out and wash it real good
Feb 26, 2015 | Heating & Cooling
Tip
Water leak in split a/c.
When compressor pumps the vapor of the freon passes through condenser coil pipelines where the heat removed by fan and becomes low pressure low temp and then travels as liquid. By removal of heat in the room again the freon get vaporized and sent to compressor. In this cycling if your indoor coil is dust blocked the room heat can't be removed. resulting this the liquid becomes forming ice over the coil. And when it cut off by coil temp, the fan only will work and ice get defrosted and water spray thr' vent.Due to coil block and makes airlock to drain pipeline. Resulting to water leak inside.To avoid water leaking service your a/c periodically.
on Jan 10, 2011 | Heating & Cooling
701 smart drive washing machine leaking but working no error
is the leaking water brown if so with it being noisier on spin it will prob be the drum bearing are on there way out
May 28, 2012 | Fisher and Paykel Washing Machines
Do I need to service, anything on the unit? Maybe oil something or ? Let me know, Its an Air Conditioning Compressor 3-4 ton runs pretty good always just seems noisier this year?
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 01, 2011 | Goodman Heating & Cooling
Top Load Ultimate Care 2 Just below the lid in
This problem is commonly caused by a water inlet valve (also known as a mixing valve) leaking by. If you live in an area that has hard water, or if you use well water, sediment, rust or calcified deposits can accumulate in the inlet valve and cause it not to close properly. Usually when they start leaking, you need to replace them. The following link explains how to access and replace the valve:
http://www.fixya.com/support/r3575881-replacing_water_inlet_valve_on_whirlpool
If the model number is correct, the part number for a replacement valve is 285805.
If you have any questions, please post back and let me know. I hope this helps you.
Jun 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Zoneline Airconditioning - Winterizing and drain line
Yes this will recycle the room and can be cover outside if it is not a heat pump and will use elec heat strips to heat. As long as it is tilled toward the back the water will run out the back without a drain kit there should also be a drain hole in the bottom.
Oct 06, 2008 | GE Heating & Cooling
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Airconditioner is on all the time now, but frosty ice is forming on the coils. The air coming out then becomes cool, but not cold and then we have to turn it on to fan in order for the ice to defrost...as...
most airconditioners will have a cutout or something called a defrost cycle, which turns it off for a while to let the ice melt. And if you run it flat out all the time this may happen too (happened to me in Thailand once, so I just turned it on when I was in my room - and it worked much better)
If it has just started doing it, the recycle timer may need repairing
Jul 10, 2008 | Heating & Cooling
Installing new airconditioner
mesure the outside dimensions and those will be the rigth dimensions to go by
May 25, 2008 | GE AJCQ08ACB Air Conditioner
Replacement
May 08, 2007 | Panasonic CW-1006FU Air Conditioner
Panasonic CW-1006FU Air Conditioner Logo
205 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
