Marantz SR19 AV rcvr.failure
The above marantz av rcvr.SR19 failed while recovering from a house power failure ,it displays 2 error messages . ACk and soon after PWR1.can help please?
  • lodorico Jun 23, 2008
    this is the second time that is happening .with the same error display.A marantz dealer replaced a power board (PS04)-WA300J401-0 ,it cost me a fortune to replace a 36$AU. I can replace the board myself if some one thinks is the same problem,and if is so ,are the boards still available for this model .
  • 1,512 Answers
Hi lodorico
Before we get too far, have you tried unplugging the unit from the wall and then firing it up about 20 mins later. This will do a hard reset on the units processor. If the first thing to when a power surge locks up your electronics.
Let me know how you got on.
robotek
Posted on Jun 25, 2008
I am getting ERROR PWR2 and ERROR ACK- what does this mean and how do I fix it?
Contact Marantz support at: http://us.marantz.com/us/Support/Pages/ServiceCenter.aspx
May 08, 2015 | Marantz SR-7000 Receiver
What can i do to stop the red light blinking for marantz sr5007?
Turn off the power using X.
2 Press X ON/STANDBY while simultaneously pressing PRESET CH + and PRESET
CH -.
3 Once the display starts flashing at intervals of about 1 second, release the two
buttons
Aug 09, 2014 | Marantz SR5007 Home Theater AV Receiver
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Marantz NR1403 standby mode only
Connect all speakers . Does it start?
If not , you have at least one audio output amplifier failure.
Seek out a Marantz dealer to help you get a tech
Jan 31, 2014 | Marantz NR1403 Slim-Line Dolby TrueHD AV...
Fix lcd cd player
Marantz US
Contact them and ask if the display uses small bulbs to backlight the display
Dec 06, 2013 | Marantz Audio Players & Recorders
Marantz SR19/U1B 5.1 AV Surround Receiver Unit powers on but will not play audio out of any of the speaker channels. Buttons respond. No further testing could be done with my knowledge.
The receiver could have gone into protect mode as a result of incorrect speaker connection in which case there should be some indication on the front panel.. Check all speaker connections as even a short between wire strands can shut down the receiver output. You may have to open up the receiver to check for open fuses in the output.
Nov 30, 2013 | Audio Players & Recorders
Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
May 31, 2009 | Marantz SR-19 Receiver
Marantz SR19 wont retain previous settings
http://us.marantz.com/SR19.pdf
Marantz says if the power is off too long it wont hold memory
Mar 24, 2009 | Nuvo Audio Players & Recorders
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
252 people viewed this question
 Grubhead
Grubhead
