Question about LG Washing Machines
LG WD-8074FHB frontloader washingmachine, vibration during spinning
My washing machine create loud noise and vibration during spinning. Machine levelling is good. Spinning without load is oke. With full load, banging the body and machine moved. I didn't see anything wrong inside the machine. A year ago I replaced bearing and after that runs smoothly.
Problem started when I put a quilt inside (machine was shaking), since them we got this problem.
Kindly advise me what can i do?
Thank you
Toni
  • Stella May 24, 2013
    I seem to have the same problem as Toni, every time I have a load on the drum inside is banging around and machine stars walking all over the place. You say that the shock absorbers at the base of the unit has come adrift from its securing point. We can't seeing anything at the base is there supposed to be absorbers at the base we can only see the 2 springs on either side of drum could you le me know regarding the base, thaks. Stella.
Toni - try WashPucks !!! We offer rubber and cork pads that go under the legs of your washer and reduce the noise and vibration. We want to make doing the laundry fun again. Learn more about our products at www.washpucks.com.
Posted on Oct 13, 2011
  • 4 Answers
As happened to me, it could be that one of the shock absorbers at the base of the unit has come adrift from its securing point.
Posted on Jun 07, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
Is there a filter in the LG INTELLOWASHER 7kg. If so where is it. The model is WD-8074FHB
its located on the bottom right of the machine front - open the flap and you will see a round filter base. ONLY OPEN THE filter during the last of the spin cycle to clean it, this is when most of the water has been pumped away. Opening it while the machine is off will cause a gush of water over the laundry floor.
Feb 08, 2010 | LG Washing Machines
Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
LG Intellowasher 7kg 800rpm WD-8074FHB washing machine now makes a very loud noise when spinning whereas before it was completely silent. machine still washes & spins OK but the noise is very loud and...
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Aug 08, 2008 | Washing Machines
7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
Feb 21, 2008 | LG WM-2277HW Front Load Washer
LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Jan 05, 2008 | Washing Machines
Washing Machines Logo
555 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
