Question about Tascam 2488 Portastudio Multitrack Recorder System
Boot in TASCAM 2488
Hey.. can you tell me how did you do the formatation of the HDD? I couldn't any place in the internet about this procedure... Thanks a lot!!!
  • irvingsr3 Sep 04, 2008
    Hi Im trying to reset my tascam to its normal factory setting....i touched the undo botton... and now i can't record anything on it.....
    Problem Solver:
  • 10 Answers
Tascam 2488You can try initializing the unit but that will erase anything on the hard drive. To do that hold down the Quick routing, Shift, Send and Shutdown buttons while turning on the unit. The unit should ask "Initialize HD, are you sure?".
Press the Yes/Enter button.
Although, when I tried this on my own machine it didn't ask 'Are you Sure?', but the initialize procedure worked.
My 2488 is showing software version 1.03, so if your system is older, it might be worth updating.
Posted on May 22, 2012
    Novelist:
  • 189 Answers
Thiagofo,
Formatting of the hard drive is outlined on page 66 of the 2488 manual (assuming this is the old grey 2488 and not the newer blue MkII).
In case you don't have the manual handy, you can either format the entire drive (excluding the fat partition) or just one of the partitions. There is also another option to refrormat the fat partition.
To format the drive, (and create new partitions), go to the 'disk' menu, highlight 'format' and press 'enter'. You'll be asked to specify the new partition size (all partitions will be the size you choose). The press 'enter' again to proceed with the format. A new blank song will be created on each partition. Do not power off the 2488 while the format is in progress.
To format a single partition, from the 'disk' menu choose 'reform' and press 'enter'. You then choose (by highlighting) which partition you want to format and press 'enter' to format. You'll get the warning/confirm message and press 'enter' again to proceed.
The fat partition (visible via usb from a PC) can be formatted also. To do this select 'fat reform' from the disk menu and press 'enter' and then 'enter' again at the warning.
irvingsr3 - I'm not sure if resetting the unit is the easiest way to fix your problem. You might be able to perform a redo, or you might be able to just go and start a new song which will reset most of the control settings to their defaults. When you hit 'undo' it may have rolled back some of your input assignments or tracks which were armed for recording and that could explain why you can't seem to record now.
bd.
Posted on Sep 17, 2008
Tascam 2488 digital portastudio
Your HD risk to be corrupted, probably need to be removed and tested on a different device, I see if I can find the schematics
regards
Mar 08, 2008 | Tascam 2488 Portastudio Multitrack...
When I turn on my Tascam 2488 it says Cannot BOOT !! Not Detect HDD correctly Please POWER OFF And Check H/W
Secure the connection of the hard drive by pushing if firmly or
by pulling the connection, then reconnect it again.
Oct 05, 2010 | Tascam 2488 Portastudio Multitrack...
Where can I get knobs for a Tascam 2488 MKII. Trim knobs
I get a CAUTION sign when I boot up that says:
Cannot Boot! Not Detect HDD Correctly. Please POWER OFF , and Check H/W..." Can anyone assit me with resolving this problem
Thanks
Scott
Feb 11, 2010 | Tascam 2488mkii 24 Track Recording...
2488 will not boot up, says not reading the hdd check the h/w .
Usually this is a problem with the Hard Drive not getting enough power to spin up properly. The AC power adapter is the usual suspect.
bd.
Oct 21, 2008 | Tascam 2488 Portastudio Multitrack...
Problem with the hdd. check the h/w
I tried everything that I can think of also, so I am going to send it into the shop. I will post what they tell me.
BR
Jul 03, 2008 | Tascam 2488 Portastudio Multitrack...
Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Jun 19, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Repartition and format the hard drive. There are specific instructions elsewhere on the Internet. I did this about six months ago. I believe my problem came about after I stored my 2488 on top of my monitors - I believe the exposure to the magnetic fields corrupted the boot partition on the drive.
Apr 10, 2008 | Tascam 2488 Portastudio Multitrack...
TASCAM 2488 won't boot up..HELP!
reseat the HDD cables, just unplug them and blow on them to remove any dust or anything on the cables and the connectors and plug them back in, but first make sure it is unplugged from the socket and once it is press the power button to let all the power out of it so you don't shock yourself , i hope I was helpful and it solves your issue
Apr 09, 2008 | Tascam 2488 Portastudio Multitrack...
before actually addressing the issue I need to know if you are sure that the unit is getting power. You may just have a power cord issue.
Oct 17, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
172 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
