Question about Intel Desktop Board D845EPI Motherboard
My pc won't power on
Pc won't power on the green light inside lights up but nothing else
  • Anonymous Nov 27, 2008
    Sometimes a defective / uder rated power supply is causing this. Defective power supply cannot provide the required load leaving your motherboard on standby mode (led green light) Try and check this first by replacing the power supply . Memory is another cause so if you also have spare you can run tests.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 126 Answers
Posted on Jun 23, 2008
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Kds k917s monitor won't turn on green power light flashes on when plugged in
check the vga cable which get loose connection then the signal from pc not recognized.
Dec 25, 2012 | NEC MultiSync Computers & Internet
HP Pavilion a 1250n won't turn on. Green light is on under the plug in the back but noghting else.
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Sep 22, 2012 | HP Pavilion a1250n (EG194AA) PC Desktop
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
Refrigerator won't run.....when I plug it in all I hear is a clicking noise in the control panel coming from a small white box with a flashing green light and the blue filter line jumps. The only sign...
It may be stuck on defrost cycle due to a bad timer... is there an adjustable switch that you could adjust it should start up... let me know...
Jul 20, 2011 | Samsung Refrigerators
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Intel Desktop Board D845EPI Motherboard Logo
161 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
