Question about Nokia 6233 Cellular Phone
My 16 month old Nokia 6288. I switched it off for 4 hours. Now it does not switch back on. When i charge it it shows its charging. But I can't switch it on.
  • tinamfong Aug 18, 2008
    Hi i have the same problem as what you have described. switched it off and now when i turn it on the nokia screen comes up but then it goes blank? I have a feeling it is a software issue but i have tried to plug it into the PC with the USB cord but it does not pick it up as new hardware on my PC? did u manage to fix your phone? Thanks
When that happened the same to my old Nokia 7600, I had to replace the screen (costed me about 100 euros on February 2006)
Posted on Nov 09, 2008
I have a nokia c3-01 (touch and type) it switches off sometimes when I am on a longer call, it switches off when I dont want to and then it wont switch on and now it wont show that its charging - i have...
change battery and if its not solve your problem then take it back.some nokia sets have charging chip problem so its also cannot be repair by repairman.and try to got repair.your set will be dead in case of repair charging chip so take it back is better.
May 23, 2011 | Cell Phones
My nokia e63 is not switching on after it was kept off for a month
if it charges charge it for 4 hours or better by another battery and charge for 3 hours it should switch on
Mar 23, 2011 | Nokia E63 Cell Phone
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
Hi, I am usinh Nokia N72 from past almost 3 years. It was working fine till 2 months back. It used to get switch off after every 5 mins..automatically. Then, we showed it at Nokia service centre at...
The battery may not be charged to full capacity. Does the battery show full charge when you charge it for 12 hours?
The adapter may be faulty. Check the battery indicator on the phone when it is being charged.
Sep 22, 2010 | Nokia N72 Cellular Phone
Nokia e63 won't switch on or charge
this have nothing to do with your phone battery and the phone charger
from your statement what you need to do to fix up the problem is that you have to make a change of your phone charging port this is well the problem is from
the charging port bad
dole it will give a sign that it charging but the same time it will discharge the power and this can cause a damage on the battery bass on constant charging
what you need to do is that you are to make a change or replace the port with a better one
if you can not do the fix up your self then you will have to take it to a very good phone work shop around you to do the fixing then your phone will work fine again
thank you .
May 01, 2010 | Nokia E63 Cell Phone
I bought t.sonic610 2gb mp3 player. around 4 months back as soon as i switch on, its gettin switched off with in few seconds..can some1 please tel mehow to rectifiy this problem... please can u give...
have you gotten it to charge fully ? 16 hours or so
also there should be a little reset switch you can put a pin or tip into and that can sometimes do the job..
if it's usb just plug it in to any computer
Jan 26, 2009 | Transcend T.sonic 610 MP3 Player
Nokia 6288 Flashing screen wont turn on
the phone's fimware needs to be reflash
Jul 02, 2008 | Nokia 6288 Cellular Phone
Nokia 6288 Problem
try one of  this steps but then read everything first
1. enter *#7780#.........this will reset your phone but you will not lose any information just the settings you applied to the phone that would be lost.
2. enter *#7370#.........this is mostly called "deep resetting" because it will reset your phone to its manufacturing settings meaning you woll lose all your contacts,messages,pictures, etc
i would recomend the second one but do not forget to backup all your information before carrying out such operations cause once it is done it cannot be reversed and also you would be prompted to enter your phone code(incase you do not remember it send me your phones IMEI or serial number so that i can send you the code)
enter the code to accept the rest...................just make sure you do not overcharge your phoneas that can also affect the charging system and in turn would affect the phone.
charge to the specified time which shouldn't be more than 2 hours then take out the charger from the mains when not in use.
this should work perfectly.
good luck
May 14, 2008 | Nokia 6288 Cellular Phone
Show test mode
my handset model1600 shows test mode , how do i turn on phone ?
Feb 29, 2008 | Nokia 1600 Cellular Phone
Nokia 6233 Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
