Question about Disney DTD1363-CAR 13" TV/DVD
DVD tray doesn't open
DVD stuck inside and we couldn't get it open
  • YAla Jun 24, 2008
    We already tried everything even to take parts off. But TV is plastic we afrade to break it.
    Problem Solver:
  • 6 Answers
Open the casing by removing the 12 screws. 2 of which on the top of the console. Believe it or not the lugnuts need to be removed for access to more of the screws.( be careful and look 2 see which ones are removable). After the tires are gone u will see screws for the fenders, Remove them and u should have enough room to access the dvd tray amongst other things!! Good luck and be gentle
Posted on Jul 01, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Squeeze opposite sides of lugnut to extract. It gets easier after you get the first one out because you can seehow the barbs are oriented. Mine had 3 screws under 5 lug nuts on each wheel. Two or three additional cabinet screws under each wheel. Don't overlook 2 tiny screws on jackplate also.
Posted on Jul 08, 2008
  • 4,472 Answers
If you know someone handy or if you feel inclined. You can try and take off the casing and manually pry it open as it may just be stuck.
Good luck and keep me posted.
Thanks,
Lee
Posted on Jun 23, 2008
  • Lee A.
    Lee A. Jun 24, 2008
    Well then there is nothing really that can be done short of have it serviced. I hope you will reconsider and at least rate this helpful.
    Thanks and if you need any further assistance let me know,
    Lee
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
When I turn on my Sony DVP-SR200P DVD player and press the eject button it's turns the DVD player off.
turn on first the dvd player and wait to read a disc inside if no disc inside the tray it will say disc error. if the unit doesn't turn off, eject now the the cd tray. if get turn off, remove the cover then check for an stuck up gear or obstruction in the cd tray assembly. you can check also the power supply board which may have unusual parts like bulged or burnt component parts.
Oct 06, 2012 | Televison & Video
DVD tray is stuck
If your DVD tray is stuck, that simply means there is a problem with the mechanism that is controlling the tray from the inside part of the player.
For you to fix this, get the appropriate screwdriver,
open the back cover of the player.
you will see a mechanism by the side of the opening and closing of the tray.
Carefully examine the mechanism, and you will detect what is faulty on the mechanism.
You can replace the faulty mechanism or better still replace the whole mechanism.
Ensure the disc tray is properly seated.
yest it with a DVD disc before you couple it back together.
Take care
Jun 18, 2010 | Televison & Video
Dvd is stuck inside and drawer will not open
Yes, it was a piece of the addhesive dot that was stuck to the back of the disk. I unplugged the unit (of course), removed the 10 screws holding the cover on the chassis and that exposed the disk in its tray. I could not manually open the tray still, but I was able to remove the tape dot from the disk while it was still in its tray. All is well now.
Dec 02, 2009 | Philips Televison & Video
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
You did not under stand
If you are able to remove the cd drive form the laptop on top there are 3 very small screws remove those and then you can remove the stuck cd
Aug 03, 2008 | Toshiba Satellite A45-S150 Notebook
DVD stuck/jammed in tray
there may be two screws on the top of the tray that holds the rounded magnet, the one that is placed to hold the disc when spinning, remove it, you can then simply take the disc out.
May 19, 2007 | Pioneer DVR-810H DVD Recorder
DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Mar 26, 2007 | Bose 3·2·1 II System
Disney DTD1363-CAR 13" TV/DVD Logo
147 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
