Question about NetGear WGR614 Router
Problem with configuring my router
My router got resetted and I need to configure,can you teach me how to do this, this all started coz i lost my wep code
  • japong99 Jun 23, 2008
    I can get into netgear smart wizzard( which is not so smart) its detecting that I have ppoa, after i click next its asking for login and password, i tried putting the serial number of modem for login and password but did not owrk, i also tried admin for login and password for password, even tried login I have to get into my email from netzero and use my password and still did not work. Its also asking if i will use dynamic ISP or choose the static ISP which when i put still no go
My router was disconnected for 2 days when i try to connect it back up i had to use the start up disk it came with but i still cant get it to connect with my lap tops
Posted on Oct 14, 2008
  • 90 Answers
Hi buddy!
first connect your router to your internet connection and click your browser like internet explorer then type the ip add. and there's a guide how to configure your router ok.
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Posted on Jun 23, 2008
Cannot connect to the router lost the password
There are two passwords for the router: the WEP/WPA password, which lets you connect to it wirelessly; and the admin password, which lets you change the configuration. If you have lost the WEP/WPA password but know the admin password (or haven't reset it from its factory default), you can connect a temporary cable between your router and your computer, and use the Easy Install Wizard or the manual configuration steps (see manual) to change the WEP/WPA password to something you know. If you do not know the admin password, then you have to reset the router to factory defaults by pressing and holding the Reset button for at least 10 seconds, and then using the Easy Install Wizard to configure it again from scratch.
Apr 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Where can I find the WEP key on my router? Router security key, router password
If you have a wireless router at home you will need to have a WEP key setup on your router. WEP stands for "Wired Equivalent Privacy" and WEP is a security protocol used to secure wireless networks. When you setup a router for wireless, you normally specify a key(password) so anyone that wishes to join your network has to enter the key. You normally set the WEP key during the router setup phase. You may have set it up and forgot it, or want to reset it. In this article I will go over the steps to find out the WEP key or change it. Your router may use a different security protocol than WEP so don't worry, you still need a KEY in order to access the network.
-On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is but depends on your router.
There are a couple of ways to find out this IP address.
-Reference your router manual
-In Microsoft Windows, go to Start > Run and in the run box type "cmd" or "command". A black DOS windows should open. In this window, type "ipconfig /all". Look near the top and you should see a "gateway address" item. This number is the ip address of your router.
Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the URL(address) bar, type the gateway address and hit enter(see image below). A log in box should now show. Again, reference your router manual if you do not know the administrative password. Enter in your password and username.
Once you log in you now have access to the router settings and you can configure what you please. What we are looking for in this article is the wireless security settings. In the wireless security settings page you should be able to see the password for your wireless network and change it. If you see no password go ahead and set one up.
**You can also look around and modify other settings. You can change the wireless security, give your wireless network a name(SSID field) and even with some routers have built in testing features to test the connection at home.
I would recommend that if your router has a default password for admin/configuration access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone. People who set up home networks tend to leave this as is and it is a security risk.
-If you can't connect to the router and you know the gateway address, try plugging the computer into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.
-Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly.
-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. Please reference router user manual for more information.
I hope this article was informative. Thanks for reading.
Where can I find the WEP key on my router?, How to reset router WEP key, lost router security key, where can I find router password, how to reset router password, where to find router security key, how to configure router security, how to configure router password, how to configure router WEP key, lost WEP key, reset WEP key, can't find my pass key, lost router pass key, lost router wireless pass key, how to reset router passkey, how to obtain router passkey
on Jun 01, 2011 | Computers & Internet
Where do I find the WEP key code on my modem model number 2247NWG
the network administrator (whoever configure your router) should have the wep key you're looking for, if you're that person and forgot your wepkey you need to reset your router so you can go back into the router configuration page and reset a new key (and hopefully you'll remember it next time).
here some instructions for your product:
check on page 14 (FAQ) of router's manual
resetting router to default configuration (router's manual)
good luck!
Dec 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Home wireless network not working
First reset your all router settings to defaults.
Press RESET button for 10 seconds it is in back side of router.
Then connect your router to computer with ethernet cable then access it with following link.
type user nams as "admin" and password as "admin" or blank or "password"
then go to wireless enable wi fi .
Then configure your router as pppoe if ity want user name and password for connect to service provider.
If you want secure then configure as WEP then go to wi fi security and set wep key it is your password to connect internet.
If you want ip addreses automatic from router then enable DHCP.
Save all settings and restart router then check.
Let me know if you need more assistanse.
Sep 03, 2009 | Linksys RangePlus WRT100 Wireless Router
Lost my WEP log in code. Have no idea what it is. What can I do? Thanks!!!!!!!!!!!
You need to reset your router.
I believe that you can do this by pressing and holding the reset button (You may need a paperclip to do this) for 30 seconds. the power LED will start to blink, and then it will reboot with the defaults. You should be able to connect to it with The default password is likely "password".
Aug 03, 2009 | D-Link AirPlus DI-524 Wireless Router
Lost wep key for router
Hold down the reset button for 30 seconds to restore the default settings, it removes all security and the wep key.
Jan 06, 2009 | AT&T 6850G Router (ALL07735)
Method to add another laptop to wireless Linksys in home. Model no: WRT546 Serial no. CDFF1G506178 password lost...tried ADMIN
just try reset in your linksys and reinstall once again the driver for it in both your laptop and set a password for it .....
Aug 07, 2008 | Computers & Internet
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to » This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Wireless password
open command prompt and type ipconfig
you will have ip address and default gateway.the default gateway number is what you need to put in to the address bar and enter into the belkin router and after loggin in go the wireless setup and configure the wep and also make sure you configure the same wep in your laptop/wireless pc.
cheers !!!
Feb 13, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Lost box and WEP codes
The most popular wep code is your phone number. if that doesnt work do OHIOTOM's solution. If you need to reset the router, do it this way. PUSH THE RESET BUTTON AT THE BACK OF THE ROUTER FOR 30 SECONDS, UNPLUG POWER FOR 10 SECONDS. NOTE; THIS WILL SET YOUR ROUTER TO FACTORY DEFAULT. If the router is reset, you have to configure it again. This time you can set up a new wep code.
Feb 07, 2008 | Linksys Wireless-G Broadband Router
NetGear WGR614 Router Logo
51 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
