Question about Whirlpool Washing Machines
Help with my top loader whirlpool
In the past few months my whirlpool slowly stopped spinning and now it only spins when empty and thats only when you assist it by hand to get going and even then its not even close to up to speed its like it lost its torque but it agitates fine and drains fine
  • zgregi Jun 23, 2008
    our washer will spin with clothes in it but i have to manually start it then close the lid and it will spin.   is this the agitator "dogs" or something more serious?
  • 57 Answers
Sounds like the plastic gear is stripped in the trany. need a new trany
Posted on Jun 24, 2008
My whirlpool machine top loader Model No. 3XLA87W72A has stopped draining and spinning. Can it be fixed?
Open the control panel and see if there is a troubleshooting flowchart for diagnosing the problem.
Jan 31, 2015 | Whirlpool Washing Machines
My cabrio top loader high efficiency low water washer is making noises
sounds like water has got past the seals and into the upper bearing.if this is the case you will hear a loud roaring noise during the spin cycle.not a cheap fix!
Dec 17, 2017 | Whirlpool Washing Machines
Whirlpool super capacity plus (commercial quality top loader) does not spin on all settings and does not spin fast enough
sounds like you have a worn out clutch. depending on model it could be an easy fix. would need to know model number to know for sure.
Apr 03, 2013 | Whirlpool Washing Machines
"2007 Whirlpool Cabrio HE top loader with glass lid" sat for 3 months, now it does everything except agitate, and flashes
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub. The image below shows how to remove the spin basket. If you unplug the washer and follow that procedure, you may find the cause of your problem.
Here is the document to help you.
Oct 14, 2012 | Whirlpool Cabrio Washing Machines
Whirlpool Ultimate Care will not stop spinning
I work on these every day for the past 8 years and have never once seen this problem. If i had to guess i would assume its a stuck contact on the timer. The timer is the only thing that sends power down to the motor but its an expensive guess.
Hope this helps _MJ_
Jan 29, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Dryer starts to run on its own
Some dryers have a touch up cycle that runs automatically to keep clothes from wrinkling if they are left in the dryer.
Some touch up cycles are selectable. Some are automatic.
Mar 07, 2009 | Whirlpool GEW9250 Electric Dryer
Won't spin heavy loads
you need a new transmission it will slowly get worse until it stops working
Dec 23, 2008 | Whirlpool LSN1000LW Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
