Question about Compaq EVO N600C (Refurbished) 14.1" LCD Monitor
EVO N600c starts up fine but when when its time to sign in nothing on screen just blank
Running xp pro , lap top was working fine then i restarted , and it started up fine until it got to log on screen which never showed up, i then tryed safe mode and the same thing happen it, starts up normal xp pro shows up on screen , then after it loads nothing , no desk top or log on screen can u help please ?
  • Quan17 Jul 06, 2008
    similar problem here.......i had shut down my computer regularly, and turned it back on later and the regular "COMPAQ" screen with an option "F10=ROM Based Setup" popped up.....after this, it normally boots up Windows XP Professional sp2, but after this one situation, windows never booted up again...CAN SOMEBODY HELP PLZ!!! I've tried everything from going into the F10 setup and changing options and even pressed F8 to see the different booting options, but nothing works.......HELP GREATLY APPRECIATED...
Both of you, what did you do before the restart? If you changed anything while in Winblows it seems likely it is a software related issue. If you didn't, then a hardware issue is possible, in which case I'd start by unplugging the non-essential peripherals and restart. If that doesn't work, also try a different power supply and disconnect the battery. Sometimes a bad peripheral can cause the boot up sequence to hang. And correct me if I'm wrong, but I believe a weak psu can undersupply power to the harddrive causing the operating system to fail to boot. But, you probably have tried these ideas so they may not be of much help. Oh well, good luck!
Posted on Jul 22, 2008
Plug & Play Configuration Error
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
hope this helps
Nov 30, 2011 | Dell Dimension 8200 PC Desktop
Just started up my Compaq Evo N600c about an hour ago as usual, the word COMPAQ came up(as it does) and then the screen went black, and around 40 short, thick, vertical, white lines appeared. Slowly they...
no photos presented of screen messing up, (sadly)
compaq = old, too old, why mess with so old a box/?
the screen is bad, and $100 is 5 times what it is worth as a whole.
find a PC 10 years or newer so its VIABLE and supported
and do not buy XP or VISTA anything,both are DEAD now.
Black with lines. (LCD problems, ('damaged")
most times means bad screen.
does the external screen work, ? at the 15pin jack there, called VGA.?
using and external screen (plugged in)
when did this PC last run good. 5 years ago?
using an external screen, re-install the unstated OS.
it came with WIN98 or XP (what it has now, click system in control panel and read what it is)
both those 2 are Dead OS/s now... dead and Virus magnets .
oddly HP has not deleted the over 10 year old support page
as most are..... that old. (you are very lucky, its like 1% chance this.)
you will need to re-Install the OS<
the media kits are here, if still suppoorted..
does this COMpaq, have the hot key F11
that when pressed at power on , wakeup the system refresh?
Apr 21, 2017 | HP Compaq Evo n600c Notebook
On start up of my compaq evo n600c the screen
Have check by a technician because the ribbon cable that runs behing the screen is loose.
Jul 16, 2009 | Computers & Internet
Cant get windows xp to load
Hit F8 while it is booting up and take it into SAFE MODE if at all possible. From there run an error check.
Go to My Computer - right click on C: -- go to properties - then select Tools - error check. Make sure you check the two boxes to have windoews fix the errors as they are found. The error check should run after you restart your computer.
if it still doesn't load.. reboot while presssing F8 and take it into safe mode and use SYSTEM RESTORE to restore computer to earlier date.
Go to:
START - ACCESSORIES - SYSTEM TOOLS -- SYSTEM RESTORE. and then select a date computer was working ok.
May 27, 2009 | Compaq Evo N600c Notebook
All white screen on compaq n600c
When you hooked up external monitor, did you switch to it via "Fn" keys?
If it did not help, then it's GPU ot North Bridge on the board that needs service.
Mar 19, 2009 | HP Compaq Evo n600c Notebook
I inherited N600C which had protected password
remove it again and make sure it inserted/seated correctly..
press power button to boot if nothing happens wait a minute or so and press and hold power button til unit turns off (you will hear this)
then reboot.
Jan 27, 2009 | HP Compaq Evo Notebook N600c
Laptop crashed
Try this:
  1. Turn on the laptop
  2. Wait for the first page to go blank.
  3. Start to press the F8 key repeadly
  4. You should get a Windows Start" page pop up that gives options on how you want to start Windows.
  5. If you see the Windows Logo (the screen you normally see when Windows starts) screen then just restart the laptop again.
  6. Choose "Last known Good Configuration" and press Enter.
If that fails then please post back and we can try some other things.
Apr 11, 2008 | Fujitsu LifeBookS6120 Notebook
I own a evo n510c
If you are hooked up the the external monitor and/or TV and can see the desktop, you can probably reselect the internal display via software from Display Properties.
In most cases you can change from the external display to the internal and vice versa by holding down the blue Fn key, and hitting the proper number on the keyboard. The correct key has a blue icon meant to resemble a monitor on it.
This is if the repair/replacment of the internal screen was done correctly and the screen is actually working. If the screen is not actually working, though, this will not help you.
Jan 28, 2008 | Compaq Evo N610C Notebook
Compaq EVO N600C (Refurbished) 14.1" LCD Monitor Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
