Question about Philips Magnavox DVD/VCR Dual Player
Cant find set up screen
Magnavox zv450mw8a c
i just bought it and i cant find a set up screen
  • 6 more comments
  • Anonymous Jun 27, 2008
    need hookup diagram
  • mariedaylily Sep 22, 2008
    I have tried every way I can think of to hook this up (Magnavox ZV450MW8) and still can not get to the setup screen. At one point I had sound but no picture (which makes it impossible to set up).
  • Anonymous Dec 25, 2008
    I have an old (1986) JVC TV model C-2175 that is connected to my brand new Magnavox ZV450MW8A unit. There is no indication from the TV screen that should be there according to your manual. I am using the CB input mode with the Magnavox unit connected to the VHF B input.
  • Shirlie White-Coles
    Shirlie White-Coles Dec 28, 2008
    I can't seem to figure this out. My magnavox zv450mw8a won't dub my vhs. i hooked it up the same way my other dvd/vhs combo drive was. (although it wasn't a dvd recorder) and i want to get rid of all my vhs onto dvd. the manual is too complicated. any simpler ways? P.S> I don't have a cable box, just a cable line coming into the house. HELP PLEASE! I'm ready to take this back and just say screw it.
  • GWOODSON22 Jan 05, 2009
    I JUST BOUGHT A MAGNAVOX ZV450MW8A HOOKED UP WITH COAXIAL CABLE FROM A CABLE BOX I CAN'T GET THE SET UP SCREEN TO DISPLAY OR ANY SIGNAL FROM THE VCR OR DVD TO THE TV SCREEN. MY OLD VCR PLAYED BOTH WITH NO PROBLEMS
    AND I HOOKED IT UP THE SAME WAY
  • colleenc243 Jan 08, 2009
    just hooked up system, but also hooked up to home theater, cannot get initial set up screen to display
  • chelsea92 Jan 10, 2009
    I can't get the set up screen. I can play vhs & dvds but I can't record the vhs to a dvd. I've read the manual but it is too complicated, I too would like something simpler.
  • fishermon886 May 11, 2010
    How do i get too, an do the set up to record from vhs to dvd?
    Problem Solver:
  • 7 Answers
The system is not easy and I have had the same problem with my moms. The one thing I know is you have to be able to get it in the setup mode for anything to work correct. If you are using the rca jack outputs in the rear (e1 is the dvd vhs video and audio out and e2 is on the front of the box and that is for video and audio in) you have to hit source and put it to e1. When you hit source on the remote it will go from tv I believe it will say channel 3,hit it again it goes to e1 and then to e2. If you are using the cable in and out put the source to tv or ch3. to record from vhs to dvd you have to push the button on the front I believe its called dubbing. It is the only diffrent colored button. This automatically sets it up you should be able to watch the video being recorded while it is recording to the dvd. Make sure you have the correct type dvd I know the +R work. It is very important to get the setup done and that is the hardest part to get too. Also remember if you are using video out(rca jacks) you must switch your tv to video in and if you are using the old style cables you set your tv to ant1 or ant 2 depending what input you are using. The problem with this is having to know your tv and what source you have set on it, ant1 or ant2 or video 1,2,or 3. It all depends on how you take the video and audio out of the vcr/dvd player. Once again if you use rca jacks you must use the remote source button and put it to e1 and then put the other end of the jacks to video input of the tv and change the source on the tv to video also. If you use the old cable in and out you must change the source on the vcr/dvd remote to ch3 and set the tv to ant 1 or 2 depending on how may inputs you have. you must match the systems. Hope this helps
Posted on Jan 02, 2009
Only spanish on screen
Posted on Jun 25, 2008
Magnavox dvd vcr combo
If the product is no longer available, then replacement parts are likely no longer available.
Jan 25, 2014 | Televison & Video
I have magnavox zv450mw8a.i can not get initial setup screen on my philips tv.
Did you try refering the user manual?Please let me know if you have one or else i'll try to give it to you.
May 10, 2008 | Televison & Video
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I just bought a Magnavox ZV450MW8A DVD/VCR Recorder. It has recording capabilities on both the DVD and VCR components but can you tell me if I can use it to record FROM the VCR directly onto the DVD? This...
Yes, you can, I have this unit and have actually copied a dvd to a vhs and then copied back to a dvd as I wanted a dvd copy to give a friend. The directions in the book are really quite simple. They tell you how to set the vhs to the spot where you want to start copying, etc.
I have not yet tried copying my family vhs tapes, but don't see a problem, just a big project. Good luck.
Jun 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox ZV450MW8A DVD won't play on PC
just bought this magnavox and have also successfully copied onto the dvd which polays in what I recorded but not in other units. Shows I have nothing on the DVD. Very Frustrating. This unit sucks big time
Mar 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Finalizing dvd on Magnavox zv450mw8a
You have to finalize after each recording and it is okay to use autofinalizing. Thanks.
Feb 11, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox ZV450MW8A can't record
Just set the channel to a non-premium channel (ABC, CBS, PBS, etc.) before starting the dubbing process.
Apr 20, 2008 | Philips Magnavox DVD/VCR Dual Player
Will not create auto chapters
Bart, many Phillips recorders seem to have a problem with creating auto chapters when it is set to auto chapter every 5 minutes. Set it to 10 minutes or more.
Mar 11, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox DVD/VCR Dual Player Logo
238 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
