My Vista HP Pavillion freezes up..alt, control delete does not work; could it be a registry problem?
  • 981 Answers
Sorry, it's completely vague why that would happen with as little information as you have provided. When does it freeze up?
Major causes could be:
You are not running a modern antivirus scan and your machine is boggled by all the rotten 'zombie' malware on it.
Your heatsink/fan is full of dust and your CPU is overheating, causing a halt (and it's old enough to do that inelegantly; but we knew =that=, I suppose....)
Your RAM got all dusty and needs to be dusted and reseated. (See a theme here? You just need that brush attachment for the portable vacuum...and to open your PC's case from time to time to see if things are keeping cool in there. If they aren't, those components will fail sooner than otherwise.)
You just added a component which caused things to keel over, because the driver for that component is old or badly written.
You started running iTunes, which eats a lot of CPU...but the Task Manager should eventually come up if this were the case.
Posted on Jun 23, 2008
How to Load or Reload"HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
Try this one:
This document pertains to HP and Compaq Desktop PCs with Windows 7, Vista, and XP. An error appears that contains a filename ending with MSI. (MSI refers to the Windows Installer.) This error can appear while Windows is starting up or when a particular software program is opened. This error might appear after using a Registry Cleaner or Registry Fix tool.
See the following error examples. Your error might be slightly different, but it has a filename that refers to or ends with MSI.
The feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package 'TrayApp.msi' in the box below.
'HPProductAssistant' the feature you are trying to use is on a CD-ROM or other removable disk that is not available.
Figure 1: Example of an MSI error
c01378399.gifUsing Recovery Manager to Restore Software and Drivers in Windows 7 HP Recovery Manager (Windows Vista)
  • HP application recovery process (Windows XP)
  • If errors persist, you can clean up the MSI registry entries by using Microsoft's automated solution. For more information, see Fix problems with programs that can't be installed or uninstalled (in English).
    Preventing MSI errors To prevent these errors from occurring, make sure that registry cleaning and spyware removal utilities do not remove files and registry entries associated with your software. Instead, if you no longer use a particular software title and want to remove all references from the registry, remove the software by using the Add or Remove Programs tool in Control Panel. The software uninstaller will remove the associated entries from the registry.
    Some products available for free on the Internet suggest that the registry needs regular maintenance or cleaning. However, use extreme caution when installing and using a registry cleaner. Many registry cleaners generate other MSI errors because they do not recognize valid registry entries and delete them. This can cause more MSI errors and prevent other programs from working.
    If you do decide to install a registry cleaner, be sure to research the product thoroughly, and then download and install programs only from software publishers that you trust .
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="" >
    NOTE:One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside the HP Web site.
    Jul 12, 2014 | HP Pavilion Computers & Internet
    How to load or to reload "HP Digitalmedia archive" file and 'EZARC.msi to my HP Pavilion a1520n desktop. (XP)
    Jul 12, 2014 | HP Computers & Internet
    With Vista Windows Ultimate, in IE9 pages take TOO long to load, bounced up and down and freeze!
    Sounds to me like a malware issue as more than one page seems to be loading at the same time. Try running Advanced System Care (by IOBIT). It is a free programme and will clean your registry and remove malware. Install their Smart Defrag as well as that is excellent at speeding up your system.
    Feb 03, 2014 | Computers & Internet
    Hp pavillion dv2000 freezes always but at different times-sometimes i can be on for a few minutes other times maybe 30 minutes before it freezes up it has been sent to hp 2 or 3 times and they cant find...
    It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
    Aug 16, 2010 | HP Pavilion dv2000t Notebook
    Every thime when i start my computer appears: insert the HP product assistent, i do ctr.alt. delete and then i can go on working, what does this mean?
    first take a backup of the registry (click on start, run, and then type regedit) ..
    once the registry screen opens, click on the top left corner, choose file and then export. You may export the copy of registry to desktop .
    now, under hkey_classes_root\installer\products .. check each entry .. if you find hp product assistant, delete the entry ..
    now, try to install the printer/or check by restarting the computer.
    Aug 14, 2010 | HP Photosmart C6180 All-In-One InkJet...
    I have a PC Pavillion with a Lightscribe DVD Writer - CD Writer ...I have had the PC for 4 years...Inserting a CD in the Lightscribe..I cannot read any files.....does not work with an audio CD either...
    Click Start
    , and then click All Programs.
    Click Accessories, and then click Run.
    Type regedit, and then click OK.
    If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
    In the navigation pane, locate and then click the following registry subkey:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
    On the Edit menu, click Delete.
    When you are prompted to confirm the deletion, click Yes.
    In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further.
    Exit Registry Editor.
    Restart the computer.
    Nov 19, 2009 | HP DVD 740VI 16X16 Dual Layer LightScribe...
    CD DVD stopeed working
    Windows XP
    1. Click Start, and then click Run.
    2. In the Open box, type regedit, and then click OK.
    3. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
    4. In the right pane, click UpperFilters.
      Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
    5. On the Edit menu, click Delete.
    6. When you are prompted to confirm the deletion, click Yes.
    7. In the right pane, click LowerFilters.
      Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
    8. On the Edit menu, click Delete.
    9. When you are prompted to confirm the deletion, click Yes.
    10. Exit Registry Editor.
    11. Restart the computer.
    May 12, 2009 | HP Pavilion tx2120US Tablet PC
    My problem is that my system does'nt show any dvd drive in lapto
    Follow the below very carefully....it usually fixes these problems. If there are no upper filters, don't worry....just delete the lower filters or vice/versa...get rid of the filters....just follw the guide below. When you get to the registry entries below, the first one maybe the one you need to edit...just read the numbers carefully to make sure you get the right one....it is easier than you think...you can do it!!!
    Windows Vista
    1. Click Start
    1. Click Accessories, and then click Run.
    2. Type regedit, and then click OK.
    1. In the navigation pane, locate and then click the following registry subkey:
    1. In the right pane, click UpperFilters.
    2. On the Edit menu, click Delete.
    3. When you are prompted to confirm the deletion, click Yes.
    4. In the right pane, click LowerFilters.
    7. Exit Registry Editor.
    8. Restart the computer.
    Nov 20, 2008 | Pioneer DVR-107D DVD±RW Burner
    Computers & Internet Logo
    35 people viewed this question
    David Payne
    David Payne
