Red convergence will not allign
I read a post here from someone else with this problem. Red convergence is off and can't be adjusted. The solution offered was to replace both STK392-110's. A link to a site was offered and I purchased them. $20 each and 2 days later I dissassembled my TV to find that my unit had STK392-120s. I doubt I can return the incorrect parts since electronics can be so fragile. Do you know if these could be used in place of the one's my set has? I'm hoping the part number might just be a model year change or something minor. They look exactly like those in my set.
I have paid for Premium Assistance already. My set is now making a high frequency sound and the set is not comming on. I did not get a chance to install the ICs bfore this happened. The set ws on and went black then this sound started. I press power and it shuts off. I press power again to turn it on and the sound pulses repeatidly. Is worth replacing the ICs at this point? Thanks.
Posted on Jun 26, 2008
How to fix red & blue lines to align, box 3,7.8 on 50H81?
Have to do convergence adjustments; provided the circuit part to convergence section works properly. Check it out first.
If it works properly, do a convergence adjustment. Do it carefully. Before start to do it, read and understand all the steps have to do.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Details about this adjustments have given by one of the posts.
Aug 23, 2014 | Toshiba 50H81 50" Rear Projection...
The colors are unalligned and the picture is blurry
hello,,the deffective part of your tv probably the convergience ic,it is a 2 pcs big ic with heatsink mounted on the mainboard you can replace it with a new one..or try to adjust first the allignment of your cathodes the RGB cathodes..on your front pannel there is a convergeance manual allignment button use this button to allign the convergeance..on your remote control there is also an allignment command consult your manual for the command .after the adjustment you must save the adjustments before exit the convergeance adjust..if thris adjustment do not work replace the convergeance ic ..mostly the ic is labeled STK XXXX..
GOODLUCK i hope i this helps you..
please rate my help tnx.
May 29, 2010 | Philips 51PW9303 51" Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 08, 2010 | Hitachi 57F710 TV
Hi. My Sony Videoscope XBR's Convergence Allignment
I happen to share this same problem. The alignment of the gridlines on the standard convergence panel are completely abnormal, and if I attempt to auto-adjust the TV, it flashes different colors on the sides of the screen , and then turns off the convergence settings.
Feb 01, 2010 | Sony Televison & Video
Convergance wont allign on 50" panasonic
Must replaced the 2 convergence ICS,and all it resistors.Must know how to solders.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts,and lobors.
Jan 16, 2010 | Philips 46PP9302 46" Rear Projection...
I am getting a double image on my 48 inch television how can i get rid of it? it is showing colors green and red on double image
Assuming that your TV is a rear-projection TV, then it sounds like the separate red, green & blue tubes aren't set correctly.
Each tube needs to be alligned exactly to produce the image on the screen. If any of the 3 are mis-alligned then the effect you describe is caused.
Somewhere in the menu settings, will be an option to set the Convergence. This option will allow you to set the allignment of all three tubes.
Older sets do not have this option, and need to be adjusted via controls on the main PCB.
Apr 22, 2009 | Televison & Video
Red and white allignment
you need new convergence Ics. This is a easy repair. let me know your model number of your TV and I will post the Convergence ICs numbers and also post a link where you can get new Ics that come with free installation instructions with pictures and free on line tech support.
Apr 23, 2008 | Televison & Video
does the crosshairs move up and down on red... do they move side to side.... if they fail to move at all then the ics must be bad and will have to be replaced.. unless your technical(xperience in solder techniques or know someone that is it will cost you about that. then after that you have to align the set which can be tricky.
sorry
Jan 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
