Sorry to tell you, but I had to send my whole unit in. They sent me back the discs and had to install a new unit. Mine was still under warranty. Best of luck!
Jan 9, 2008 - So when I tried to play a CD that has been in there forever, ... had that problem too! it would be in 50 degree weather.. discs wont change, play or eject. garaged the .... So last week I took my 06 (w/ Bose) in to the dealer for the stuck CD. ... said they send the CD player back to the factory and they will get the ...
Acura RSX-type S where is the reset botton on a Bose 6 disc in-dash cd player. I have a CD stuck in the CD player. Need help getting it. Everything I read is telling me to push the reset button.
Had this happen to my 6, they had to remove the CD player and send it away to get the disc's out and they mailed them to me, installed new bose disc changer under warrenty no problems since.
There may, or, may not be a small pinhole in the front panel of the changer. If it does have this hole, take a paper clip and insert it straight into the hole and this will enable manual ejection of the disk tray. If the hole is not there than the housing has to be removed to gain acess to the disks. Thank you, Dana
The case needs unscrewing to reveal more of the internals. Go carefully and peer inside wherever you can to fiddle the CD back into place or out of the box. It's in there somewhere, removing panels will get there.
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix thisissue or, you can just purchase a new changer and save a lot of money.
you can try disconnecting the battery for 10 min. to reset the system. If that dosent work then you will need to send the radio into a repair shop to have them manually remove the cd and repair the changer. (the changers are very fragle and break inside) you can send it directly to alpine to be repaired.their number is 1-800-421-2284 ex 860304
the cd is stuck inside the bose radio sistem
