My simson encore 703 when it starts to agetate whenit turns to the right it turns quickly and the clothes get tangled around the agitator
  • 1 more comment
  • kevin67 Jun 23, 2008
    where is the coupler and the pin i cant see it on the digram
    thank you for your help i will now try to fix it
    your details seem simple, and much cheaper than
    geting some one to call for a quote
    best regards kevin67
  • Anonymous Mar 14, 2014
    Our machine will only turn one way and ends up tangling the clothes, it has recently started leaking, can you help?
    Genius:
  • 1,142 Answers
Attempting repairs can be dangerous.
In many instances work should only be undertaken by a qualified professional.
This problem seems that the agitator motor or the gear has gone bad so it would be recommended to consult a tecnician
Posted on Jun 23, 2008
    Guru:
  • 1,894 Answers
Result from a simple broken pin, which causes the tub to spin whenever the motor runs, even while agitating. Call to find out how to fix this common problem – it’s very inexpensive.
  • 2 more comments
  • dewan nafees ahmed Jun 23, 2008
    Warning! To
    avoid personal injury or even death, always disconnect your appliance
    from its power source--that is, unplug it or break the connection at
    the circuit breaker or fuse box--before you do any troubleshooting or
    repair work on your appliance. Also, because some components may have
    sharp edges, use caution while working on your appliance. It blows fuses or trips the circuit breaker: Some
    appliances use 220 volts or two power lines of 110 volts each. Do not
    touch any power sources – 220V is DEADLY – in seconds!
    this diagram may help u
    If you can pull the agitator off, there should be a plastic hub, with a
    screw in the center of it. That is what needs to be replaced.
    also u may also have to replace the coupler if problem persists.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
    since they are very small details they are omitted in the digram i think.
    look at the note in side of the diagram
    many details omitted for clarity
Why does the agitator keep getting stuck and will only go one way
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 26, 2015 | Washing Machines
Hi my washing machine is tangling up all the washing around the agitator then going out of balance, stops spinning, lights start flashing and beeping? Please help me...
Make sure the agitator is down as far as it can go on the shaft. If it has worked itself partially off the shaft it can cause a gap that will cause your clothes to tangle around the agitator.
Dec 09, 2014 | Washing Machines
Simpson agitator
I have the same problem, seems as if this washer always tangles the clothes, there is really no solution.
Aug 25, 2014 | Simpson Washing Machines
Simpson encore 605
Yes its a top loader and cloths are distributed evenly at the moment. My problem is it will not agitate. Its like the brake is locked on. It spins fine but niether the drum or agitator move. the motor is trying but its cant over come the brake (i think). I have had the brake arm off but I am unsure if it needs alinging with the brake tang when putting it back together ?
Jan 05, 2014 | Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
Clothes get caught under the agitator and tangled around the agitator and have to unravel the clothes from the agitator
Check the rubber gasket around the agitator is not worn. If it is get a replacement and insert it in snugy.
Aug 16, 2010 | Whirlpool LSQ8543J
Agitation issue
So you say the agetator is moveing or when the clothes go up and down does it stay in place and make a rattcheting sound. if it is not moving the clothes up and down you need new agetator dogs. pop the cap off the top of the agetator some have a plastic cap that you can poull off to get to the 1/2 inch screw inside. some don't if you can see the bolt around the edges of the inside of the agetator you will see groove marks and when you turn the agetator by have you will see 4 plastic tear drop looking thing that grab the grooves of the agetator these tear drop things get stripped over time. replace them and this should solve your problem. let me know if you have any more questions
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
ON SPIN CYCLE AGITATOR MAKE A LOUD BANGING SOUND
So while you are holding the agetator is it ripping your hands? or is the agetator just sitting there? If the agetator is just sitting there you probably have bad agetator dogs. I would remove the fabric softner or cap whichever you have. under the cap you will see grooves in the agetator down low. When you manually turn the agetator you should see 4 tear drops that grab the grooves if you do not see this you have bad dogs. Very simple. This usually is the cause for the grinding noise that you are hearing. Please let me know if this works for you //eg
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator Dogs tangle clothes
No - The clothes will not agitate properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
