Question about Pioneer DEH-P6800MP CD Player
Alpine deck when the bass of a cd hits the cd skips
  • 24 Answers
Check rubber suspention of cd mechanism, down side of the mach, may be punchared.replace it, or cd and woofer/speaker on the fixed on same platform then due to vibration track maybe
changed
Posted on Jun 25, 2008
How do i fix my bass and treble on my deck
If you are having distorted or muffled sound from your deck then this could be caused by either 1)poor settings 2) bad output amplifier or 3) blown speakers, inspect 1 and 3, if ok then is 2. hope this helps.
Sep 30, 2009 | Alpine CDA-9831 CD Player
My alpine ida x200 keeps skipping during songs
All you can really do is use a CD Player cleaner *one that uses fluid* run it thru a couple times and try a disc again. Clean your CD's with liquid car polish an a microfibre towel, it works wonders for new and old CD's. If it still skips, It needs to be pulled for repair. They just replace the transport, usually runs between 100-150 depending on the service center. Hope this helps.
Aug 11, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
BASS,TREBBLE,MIDS SETTING
Hello 1rocknroller,
Press the mode button repeatedly to select BASS, TREBLE, SUBW, BALANCE, FADER, DEFEAT, AND VOLUME. When subwoofer mode is set to off, it's level cannot be adjusted. If DEFEAT is set to ON, the player returns to factory defaults. Turn the volume control to adjust the setting. If no adjustment is made within 5 seconds after selecting, the player returns to normal mode.
Hope this helps.
May 29, 2009 | Alpine CDA-9856 CD Player
I have a jvc stereo hooked up to two boss subs. and a alpine 300w amp and when i turn it up the cd player skips
Make sure that the head unit is secured tight, it might be the bass that is rattling the head unit and therefore the cd is jumping.
Jan 10, 2009 | Car Audio & Video
New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Aug 24, 2008 | Alpine CDA-9833 CD Player
CD skipping with the bass
Has it always done this, or is this a new problem? If this is a new problem you may need the unit serviced. It may need the lens cleaned, or laser replaced. If the laser is getting weaker it can do that. They also have these small oil filled dampers used like shock absorbers. If one of those is torn and has leaked a little oil out it will skip much easier. They also use springs to support the cd mech, if a spring has streched out or come loose, that can also make it skip on big bass hits.
You can always try putting some foam or something around the radio to help keep those heavy bass hits from vibrating the radio. But then the radio may get too hot.
Make sure the radio is very secure in the dash.
If this problem has been going on since you installed the radio, you have an installation problem. The radio is a little loose and prone to move around a little.
May 16, 2008 | Pioneer DEH-P6800MP CD Player
Not enough bass
its prolly the deck, did you try turning the alpine's input gain controls up...
its not the wiring, if the wiring was insuficient, it would just melt...
you might also see if you could adjust the bass frequencies or crossover frequency, the crv might just have a different resonant frequency then the rav 4
May 16, 2008 | Alpine MRP-M450 Car Audio Amplifier
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Aug 10, 2007 | Alpine CDM-7861 CD Player
Pioneer DEH-P6800MP CD Player Logo
27 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
