Question about E-Machines Computers & Internet
I have an E-Machine W3107 desk top. I recently installed a western digital 120 hard drive as a slave but it would not jump. Can you give me any help in getting my system to jump. Thank you.
  • 3 Answers
I'm sorry I'm not sure what you mean by "jump". If you mean to be recognized as slave & you already have a master hdd make sure you have jumpers on both hdd's set; master as master and slave as slave. Using cabel select requires (I could stand to be corrected) one hdd cable with at least 2 drive connections on it, and you would want your 2nd (slave) drives jumper set as CS.
Then it's best to boot into the bios and see if and what the drives are being recongnized as. Sometimes it helps to set the second one (maybe both) on Auto. If still not recongnized try the 2nd drive setting on User.
I hope this pertains to your promblem as I'm not sure what "jump" means. If not, please detail your problem further and I will
try another alternative.
Posted on Jun 23, 2008
  • 981 Answers
Jump? Ha! Never heard that term. How about boot?
Nowadays people just load drives as Cable Select; it should have worked with the old drive set to Master, but try to set them both to that and try again, or boot to a LiveCD or the drive utility disk so you can configure them on that. If they don't appear correctly in the BIOS, just double-check that power and data cables go to each drive, etc. You may need to follow the BIOS instructions or enter the BIOS controls by hitting DEL or F10 on powering up until the menu appears; then you can select the drive to try to boot first, etc. and save your settings.
What is the jumper setting for wd200bb 20gb hard drive for slave
Slave - Installing the new drive as the secondary drive:
If installing your new Western Digital hard drive as the secondary drive on the cable with
two IDE devices, move the jumper shunt on the drive to pins 3 and 4. If necessary,
configure the jumper on the other IDE device as Master.
May 04, 2011 | Western Digital Caviar WD200BB 20 GB Hard...
Can I use my current w d. external hard drive with my laptop computer as well as my desk top.
you can only use it as an external on the laptop if you use it as an external you can use on the desktop just plugging the usb also if your motherboard has sata conection you could install it into your desk top.
Oct 06, 2010 | Western Digital (WD3200JS) 320 GB Hard...
How do set the jumpers on the HD to slave ? thanks
you can find the jumper settings printed on the top of western digital caviar hard drives
slave setting with the hard drive end jumpers facing you is 2nd from the right or 4th from the right
good luck
Aug 28, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Found my old HD (Western Digital WD1200JD) and decided to use it as a secondary to my much smaller HD. I've plugged in the SATA port, heard it turn on with its unique noise, and I've gone to see if it was...
You need to configure first on your BIOS that it will detect 2 SATA Hard Disks so and set you Primary and Slave. If this doesn't work, basically your HD does not work anymore.
Mar 09, 2010 | Western Digital Caviar SE WD1200JD 120 GB...
I installed a new western digital hard drive in a compaq desk top. I can't find the boot order to make the cd read the windows install CD
While the computer is starting, look for the compaq splash screen or just start tapping F12 when the computer starts, it will flash up a temp. boot order menu, choose your cd and hit enter.
Sep 14, 2009 | Western Digital (WD3200JS) 320 GB Hard...
IT LIGTHS UP BUT CAN'T GET MY COMPUTER TO RECORNIZE IT
TRY TO CHANGE MASTER SLAVE JUMP AND GIVE MORE INFORMATION TO HELP YOU
Jul 15, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Does not get recognised by Desk top or Laptop Asks for Installation and drivers
these drive require a usb 2.0 port.
If you are using XP and do not have a 2.0 port in your computer
you may want to get a USB 2.0 pci card this will help.
if you are using vista, it should install the driver automatically.
also do not use it on a hub plug it into a usb port on the motherboard or a powered card.
Apr 14, 2009 | Western Digital Passport WDXML800UE...
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
Western digital Scorpio 120 G
Actually there is no solution, the hard drive is bad.
What I ended doing was recording the partition in iso. ( I had a Factory Partition)
Got a new hard drive 160G scorpio unfortunately it does not come with installation disc.
Installed Vista, and with vista created a partition and then installed the contents of the factory partition.
Feb 18, 2009 | Western Digital Scorpio WD1200BEVS 120 GB...
External Hard Drive Installation
MAKE IT A MASTER FIRST ..IF NOT THEN MAKE IT A SLAVE.
IF ITS A SATA THE PCB HAS A JUMPER SETTING TO SET IT SLAVE ..MAKE IT A SLAVE FIRST IF ITS SATA
Jul 22, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Computers & Internet Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
