Question about HP Pavilion dv1000 Notebook
No power All lights come on HP Pavilion dv1000 but will not boot. looked at motherboard and by power connector there is a blown part the number on the board shows PD27. I need to know what thhe part is or a schematic showing the parts
  • Anonymous Jul 04, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to chuckrrister's No power problem, and notify you when a new solution is offered.
Posted on Jul 04, 2008
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
I have a hp pavilion dv7 and the power socket has come a lose i need to know which wire goes where.....
The DC Power Jack that the AC adapter (Charger) plugs into?
Look into the DC Power Jack with a magnifying glass and light you'll see it's a center pin surrounded by a barrel. Barrel has an inside and an outside.
1) Center pin. Gold and buried down in the plastic. Connected to WHITE wire at motherboard connector.
2) Inside barrel has 4 Brass fingers.
Orient the laptop so the LED is at 12 o'clock and you'll see fingers at 12, 3, 6 and 9 o'clock.
These fingers carry the + 19 volt power to computer.
The ones at 6 and 9 o'clock do, Noon and 3 are not connected.
+19 Volt power arrives at motherboard connector on RED wire.
3. Outside barrel has six brass fingers, at 2, 3, 4, 8, 9 and 10 o'clock.
2, 3, and 4 are not used,
2, 8, 9 and 10 are the power return (common, or ground) to computer.
It arrives at motherboard on BLACK wire.
4. LED is connected to YELLOW wire and controlled by computer.
Other side of LED is jumpered to a Black wire,(Ground), outside barrel 8, 9, and 10 o'clock.
From > analog posted in an HP Support Forum.
Nov 12, 2010 | HP Pavilion dv1000 Notebook
Hp dv1000 screen does not show anything
there is a common problem with these laptops the motherboard faults if the power led lights up but nothing else then that the problem
May 28, 2010 | HP Pavilion dv1000 Notebook
Motherboard DV1000 DA0CT3MB6G6 dead or faulty
I will provide you the part number for the motherboard, you can find the motherbaord online. It will be costly, try searching for cheaper price.
393656-001 : 915GM
393655-001: 910GM
Feb 07, 2010 | HP Pavilion dv1000 Notebook
I bought a new ac charger for my hp pavillion dv1000 it will not power on
Check and make sure the Voltage on the AC adapter is the exact same as your previous one. Just because the connector fits in the port, doesn't mean it's the right one. Look in your manual to figure out if your AC adapter voltage is correct. If it is, it's possible that you have a dead battery, it happens when surges happen during power outages. If it's so, look on the HP website for a new replacement battery. It should allow you to type in your pavillion model number.
Jan 08, 2010 | HP Pavilion dv1000 Notebook
I want the replacement motherboard part number
The part number you posted on the FixYa site is correct for a replacement board. It is actually designed for the DV1300 series but will work iin many DV1000 series notebooks. If you get on E-Bay and put that part number in the search box, you will find many that are for sale and under 120 bucks. Good luck
Nov 25, 2009 | HP Pavilion dv1000 Notebook
My hp pavilion turs on and the led lights stay light but the computer won't boot up
look remove every drive connected to you computer and then remove the battery and connect the computer on the charger only and try to open the computer
Nov 08, 2009 | HP Pavilion dv1000 Notebook
HP dv1000 will not boot, no power. Is this a hard
No Power at all sounds like the Internal DC Power Jack that is soldered onto the motherboard is bad. Send it to these guys www.generalsystemsconsulting.com
Mar 08, 2009 | HP Pavilion dv1000 Notebook
Power issues on HP DV1000
It is possible you have two dud batteries. Recharageable batteries have a limited life, they have a finite number of charge and discharge cycles.
With the battery removed and only the power supply connected and the laptop powered up, when you touch the connector on the laptop and the laptop does not shut down then the laptop connector is OK.
If you can verify your new battery is OK the the fault could be the power supply adapter, if may not produce enought current to run and charge the battery. Try charging the battery overnight by turning off the laptop and leaving on the mains t charge. Borrow a mains adapter and test it on your computer.
You can also check the BIOS setting for power management, ie. hibernate, low power shut down etc.
Dec 03, 2008 | HP Pavilion dv1000 Notebook
No power
Is that little diode located near PL7? If yes It's SMD code looks like "6." and "J." but that J is bigger and lifted up. I have no clue what kind of diode it is but its Diode for sure - I've measure it. Anode is facing to PC146 and cathode to PR153.
Good Luck.
Slav
Jun 23, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
390 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
