Question about Cameras
I have a JVC videomovie GR-AX37 compact VHS random Assemble editing VHSC W/ TC-30 compact cassette. While I am recording the picture looks great. but when I play it back, the film rolls. when it is playing in fastforward or rewind it doesn't roll but there is lines in it and it is hard to see that fast.
5 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Posted on Sep 24, 2007
  • 579 Answers
SOURCE: VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Posted on Jan 22, 2008
battlesmith
  • 382 Answers
SOURCE: Cassette Recorder play problem
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
Posted on Jul 24, 2008
Benimur
  • 6966 Answers
SOURCE: Picture rolls on playback
I beg to differ that the head is dirty. This is based on your post "...pre recorded tape is played the picture is fine..."
I am more inclined to suspect:
  • servo calibration. This would be the capstan motor controller. The recording speed slightly differs with the playback speed. You could try manually adjusting the tracking control and see if it corrects the problem;
  • recording speed selection, LP, SP, EP/SLP. try recording at the lowest speed LP;
  • video source, possibly of a different color system, PAL, SECAM, NTSC.
Hope this be of initial help/idea. Pls post back what is your video source, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 24, 2008
welcomejee
  • 10594 Answers
SOURCE: jvc GR - D30U model
Do you mean you cant see live view in LCD or viewfinder to record.
if it is, then its problem of bad ccd imager in your JVC camcorder.
JVC will repair this model free of cost for ccd problem.
Click JVC CCD Support for details / info how to get free repair.
Posted on Dec 26, 2008
I need a manual for a jvc 600x digital zoom compact vhs camcorder model no. GR-SXM750U
Welcome to Fixya.
Here's where you can view/download your user's guide for this camcorder :
Camcorder User's Manual
Thanks for using Fixya.
Sep 22, 2011 | Cameras
Video camera appears to record, but nothing plays
Try to run cleaning tape, it may solve your problem.
Nov 21, 2009 | Cameras
Brand new jvc gr-d850 camcorder. Picture quality is great, but cannot get the sound recorded. Complete silence on playback. Manual isn't much help, this problem is not even addressed in the...
Silence on the camera, or when listened on computer? Because some cameras dont have audio playback on camera. Try plugging in headphones....
Aug 04, 2009 | Cameras
JVC GR D247EK #140M0089 - Camera stopped loading cassettes. Remains in eject position.
Remove the battery for 30 minutes and try again. When putting the tape on camera press only where indicated by an arrow. Good luck!
Nov 20, 2008 | JVC Cameras
I have a JVC digital video camcorder GR-D90u and no picture comes up on the lcd monitor so i can record.....can you help...also I need help on what I need to connect to my tv so we can watch what's been...
Symptoms in your JVC GR-D90US shows problem with CCD Imager IC and this part needs to replace.
JVC has Free of Cost repair scheme for subject model camera having same problem. Isn't good news?
Click JVC Support for details how to get free service.
Regards,
Sep 14, 2008 | Cameras
I have a jvc mini dv GR-D23EK camcorder. It usually works absolutely fine but I have gone to use it after it being charged and you cannot see anything through the lens. It is picking up and recording sound...
JVC camera has common issue with CCD Imager defects. Please mention correct model and your country name to provide you further help as JVC has free repair scheme for few models. I couldn't find GR-D23EK. Just as reference, click JVC GR-D22US to see problem and details.
Regards,
Sep 05, 2008 | JVC Cameras
I have a JVC Compact VHS video camera, model GR-AX800 and it's beginning to eat my tapes. There's an error code, "E08" appearring in the viewfinder. Can you tell me what that means? ...
Either a belt has broken internally o is sliping enough to prevent the takeup reel from turning. This unit needs service. This is not a repair I would suggest you attempt unless you have worked on cameras before. The parts cost for this repair should not be more than $10. Check around for a service center that will work on JVC camcorders.
Dan
Aug 01, 2008 | JVC Cameras
Video Camera Malfunction
http://www.circuitcity.com/ccd/productDetail.do?oid=170896
This is a link that has camera reviews on it.
Apparently the camera that someone reviewed there goes fuzzy.
Mar 16, 2008 | Cameras
Cameras Logo
102 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
