Question about Compaq Computers & Internet
I moved my computer and when i did, it would not come back on. Monitor works but something is wrong with the brain--light comes on, but I don't hear it running. when this first happened it asked about recovery and then I don't know3 exactly what happened. does it need reset or whatever? Also, as stated, I don't hear it "gearing up" ike it used to. It is only six months old.
  • 871 Answers
Try to check if you plugged all the correct sockets into place. check if you also got the outlet correct. this may only happen if you got something moved specially the towercase. if all connections are ok, check inside your tower if the RAMs are correctly seated. those are your memory.
Posted on Jun 23, 2008
My friend karen press the power button, thre is no power... there blinking lights on the back of the computer near the fan power ...
Do you hear the harddrive start up? When you push the power button (or switch on the back) do the lights go out? If you hear fan running and hard drive start up then the computer itself might be on but the monitor isn't. Check the power to the monitor, the connection between monitor and computer to make sure they are all on and connected.
If you don' t hear the fan running then you have other problems. Any blinking lights would indicate something is getting power. I'm assuming the computer was working before the power button was pushed... If the monitor is actually working, you could hook up another monitor to check too then you have other problems but need more info to know what that could be.
would need to know the answer to the above questions as well as if it was working before, what was done, what changed between it working and this problem. Also what age the machine etc.
Jul 06, 2011 | Computers & Internet
Monitor is getting power but no sign of life. Even the On/Off button has no illumination.
Most cases of a monitor doing that would have something to do with the cables and ports. Ensure that your video card is mounted properly (don't do this while your computer is on), and check the plug in the back to make sure it's firmly attached. If all of this is alright, check the input ports on the back of your monitor, you may have a plug in the wrong slot or not in at all. Another attempt at solving the problem can be made by hooking the monitor up to a laptop or another computer to see if it turns on, if it does, there's something wrong with the computer itself. Anything wrong with the computer can include: An improperly mounted video card, a video card not receiving power (some cards require extra power, if you have an older card, don't worry about this), or your motherboard might have a physical issue (most likely not the case.)
May 06, 2011 | HP w1907 LCD Monitor
Monitor keeps shutting off and will not come back on unless i shut down the tower....what is wrong with the monitor, do i have to get another one?
With a monitor there a a number of things that may be causing the problem.
Firstly - if you unplug the monitor cable from the computer and start the monitor does it work: (should turn on and give an error message (no video input found or something similar). In this case the monitor is good and something is wrong with the computer.
If the monitor does not work then the monitor is at fault and it is likely the inverter is tripping the power out. that means a component is shorting or it is burnt out. These can be replaced but you are getting close to the cost of a new monitor to replace them.
Please let me know if the monitor is the faulty item. If it is not we can move onto the computer to see what is at fault or I can give you more details about repairing a monitor.
Mar 07, 2011 | HP Compaq W17q Wide LCD Monitor
Our computer monitor is not coming up. how can we tell if the monitor is bad or something else is wrong?
The most obvious way to tell is to swap out the monitor. If the new one works, the old one probably has a problem.
When you say "is not coming up" I assume you never see a thing on it. I would ask--do you hear the system beep once indicating that it has passed the POST? If not (and it always did), then I would suspect that since it hasn't passed its own diagnostics, you will never get a signal on the monitor.
I suggest disconnecting everything on the computer but the video, memory, and CPU (you can leave the mouse and keyboard connected).
If the system starts and displays something (most likely you will see a message indication no boot device), then you can assume you have a problem with a piece of the hardware.
Also, if you hear a series of beeps, they will help you troubleshoot.
Jul 12, 2010 | Samsung SyncMaster 953BW 19 inch Monitor
Monitor is black...checked all connections..OK. Turned computer off and back on,still no screen. HELP!!!
The first thing I would do if possible is hook up another monitor to the computer to see if that one works. If it does, then your monitor has gone bad. If it doesn't work either, then your video card has gone bad. Did you hear any beeps when you started up your computer? If you did, then this usually means there is something wrong with the video card. Also, sometimes the power button is turned off. Are there any lights lit at all on the monitor and are they green or yellow?
Aug 18, 2009 | Gateway FPD2275W LCD Monitor
Monitor will come on for 1 second and then go blank and the power light go from blue to red then if you cut power back on it will come back on for a second and then shut off
moniotr switches into power save mode when it is connected to the computer and there is no signal for the computer. Try following the steps below which i recomended for another poster as well
Unplug the monitor from the power
Unplug the monitor from the computer
Plug the monitor back in.
Try turning it on.
DOES IT SAY "NO SOUCRE DETECTED" or soemthing like that???
if it DOESN'T it means there is something wrong with the computer.
if it DOES:
plug it back on to the computer, turn the computer power off.
Press and hold the power button on the computer for about 15 seconds.
Plug the computer back on.
Try turning the computer on.
if it's not turning on again there a problem either with your monitor cable, or the plug, or the video card plug. It is unlikely that your video card is broken if you hear no wired series of short and long beeps when you try turning the computer on.
Good luck.
Give us updates if you need more assistance
Aug 11, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
Mar 27, 2009 | Samsung 941BW LCD Monitor
Screen not lighting up and staying black.
if the green light is always on that means there is no prob concerning the power and the monitor itself. the problem seems to be coming from your graphic card..
try with another graphic card..
OR
you might not configure the screen resolution to the appropriate level..
can you run your pc correctly in safe mode??
Jul 05, 2008 | BenQ FP567s 15" LCD Monitor
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
Screen black
Bill, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually and economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 06, 2007 | Samsung SyncMaster 910T 19" LCD Monitor
Computers & Internet Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
