Question about Magic Chef CES3760 Electric Kitchen Range
Hot Surface indicator light
The Hot Surface indicator light will not turn on...all the burners function properly.
  • Anonymous Dec 11, 2008
    All of the surface burners work properly, but the Hot Surface Indicator Lights do not come on upon turning the burners on.
Hot surface indicator light stays on despite the burners being off overnight
There is a switch in the burner assembly that senses the burner is hot. It could be the sensor switch is bad. It also could be the surface switch itself that has a welded contact that is causing the hot surface light to stay on. i would look at the thermal switch on the burner itself first.
Mar 22, 2015 | Kitchen Ranges
The burners light indicator stays on even when the burners are turned off
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on heatman101
Apr 23, 2011 | Microwave Ovens
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Jan 18, 2011 | Maytag Cooktops
GE EVOLUTION Glass top. The hot surface(Glass top)
Individual burners, located directly under the cooktop glass, contain a temp sensor which lights up the hot surface lamp when they sense a hot condition. If the light stays on after all burners are cool, one of the sensors has shorted out. The sensors are an integral part of the burner, so the offending burner must be replaced to solve your constant on hot light.
Jul 01, 2009 | GE Kitchen Ranges
I have a new ge range. When I turn on the left
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
Apr 11, 2009 | GE Kitchen Ranges
GE Spectra JBP30B0B4WH surface unit light stays on
If it's the light that indicated the element is on, replace the switch. If it's the light that indicated the element is hot, replace the element.
Jun 05, 2008 | GE Spectra JBP78 Electric Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Magic Chef CES3760 Electric Kitchen Range Logo
83 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
